Disable TPMS?
#46
I got an F250 mainly for the solid Dana front axle, (4WD performance), will never haul big loads. I got load rage D tires on advice that I could adjust the TPMS, even paid for new monitors. Resultingly, TPMS continually complains. I figure if there were "hack" tools available, someone in this thread would have mentioned them by now, so I won't ask. However, a few other things were mentioned that caught my eye:
-> "Reset" option in the menu
-> Green button in the glove box
-> pp 229-231 in the manual
I could not find the green button on my 2010 F250 glove box, and the manual talks about tire pressure but nothing about resetting TPMS. It is mentioned in the computer system check though. I wonder if there is some secret button push pattern you can do to reset the pressure?
For my situation, I would sure love to set the TPMS much lower. All I care about is if I have a leak and the tire is getting soft, so 30 lbs would do it for me. Still hoping to hear something good. I expect it will be something you can do through the OBD port or some hidden USB to lower the computer's threshold.
#47
I found a way to do it. I found a guy that does Air bag service. He connected to my computer in my truck and lowered the system air pressure point. Instead of the fault coming on at anything less than 75, I had him lower it to 65. 65psi is the max for my after market tires. Light is off and does not turn on unless one of my tires is lower than 65psi.
The tire revs per mile can also be changed to a certain extent if you change tire sizes. I bumped up a size or two and the guys at 5 Star told me what the revs needed to be set at.
#48
Back in the day
I have oversized tires without sensors. I didn't want to buy new higher pressure ones. I just deal with hitting the reset on my digital readout. But, back in the day you checked your tired the old-fashioned way no sensors needed. You should be anle to disable them but, ohhh well.
#49
He is right, I am a mechanic at a tire shop, and it is illegal to disable it. I have seen customers do it if they buy aftermarket rims and can not get sensors for them, most of them just unplug the bulb, but depending on your setup that wont work (if you have a digital display, or a warning buzzer).
Why would you want to disable it? If you get into an accident from a blown out tire (overheating from underinflation) and they find it has been tampered with, You would be looking at major court time even if no one gets killed.
Lowering the psi can be dangerous and expensive. Not only do you risk overheating the tires and having a failure, but at the bare min. you will decrease the life of the tire. Under inflated tires will wear faster at the edges, and the sidewall will flex more cousing it to crack and dry out reducing it's strength. I have had many cust. replace tires at half life because they were cracking and had excesive edge wear from underinflating. The center tread would still be good, but the tires can not hold air very long from the cracking sidewalls.
Lowering the pressure just isn't worth it, sure you may get a smoother ride, but you bought a FORD SUPER DUTY PICK UP not a f***ing Mercedes. The truck is made for work.
#50
If you have to lower them for traction then the light should be on to remind you to fill them back up.
the majority of the systems available are REPROGRAMABLE. When you "RESET" the light on 90% of vehicles, it gets reprogramed to what ever pressure you currently have them at. I had a customer just today came in for an Oil change on a Toyota, the tiretech doing the oil change called me over because he noticed that one tire was at 15psi but the tpms light was not on. after talking to the cust. we found out that they learned how to reset the light and instead of checking her tires she just kept reseting the light. Turns out she had a small bolt in the tire and the system was warning her about it, but she decided to cover it up, if we did not check her pressures she very likely would have had a blow out sice she does alot of highway travel.
Tpms was made a requirement for a reason, not just for you saftey (like seat belts) but for the saftey of other peaple on the road. If you have a blow out in one of these trucks, that can lead to loss of control and possible rollover, putting others at risk.
CASAJOE
6.7L Power Stroke Diesel
04-02-2017 11:53 AM
