You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
__________________
Tony 1994 F250 XLT ext. cab,long bed,7.3 IDI factory turbo,4x4,manual hubs,E4OD,4.10 gears, K&N air filter,Hayden 679 trans. cooler,PSD oil filter,coolant filter and vac. operated heater shut off valve, manual glowplugs,Autometer water temp.,trans. temp., and pyro in three guage pillar pod, Autometer mechanical oil pressure under dash with twin vac/boost guages,TruxPort tonneau cover,straight piped,189,000 miles and counting. 88 Ranger 2.0, 5 speed,147,000 mi.,bought new.NC Chapter Member,IUE Retired, NRA Life Member,USMC.
Which day are you planning on going this month Scott, 14th, 15th or both?
__________________
15th most likley. I may swing by friday night but by the time I get out of work and drive home (45 minute drive) then another 20 the the pull It would about be to late.
__________________ -Scott
SOLD 2-28-11.....
'06 F250 CC/SB PSD. 2'' lift, Bilstein 5100's, Dual stabilizers, 20'' Harley wheels, 35-12.50 MT ATZ's, 08 Mirrors, ARP studs, EGR delete, 4'' MBRP, X3 with custom tunes, Full gauges, scangauge II, Coolant filter, Red top Optimas, DC 185a alt,
Had a good turn out last night. Didnt break anything so it was a success I guess. With my new tune that I just got I am SERIOUSLY running out of fuel, stock system cant keep up. Firday night the sled broke so we did some side by side dirt drag racing
SOLD 2-28-11.....
Good to hear the tune is working. How do you get more fuel with that PSD?
Mine is easy , you just turn the screw on the IP, but I can't make enough boost to to need more fuel.
__________________
Its not fuel pressure that I am running out of, its volume. I can adjust my pressure anywhere I want too at idle but no matter how high I set it when Im on the fuel the system cant supply enough quantity. I need bigger pump and bigger lines from the tank to the engine. Thats not in the budget right now with twins on the way so it will have to wait.
SOLD 2-28-11.....
