Clutch Safety Switch adjustment Question
Good day,
I own a 1994 F350 with the ZF 5-speed.
When starting the truck, I must push the clutch pedal all the way to the floor, and then a tiny bit more in order to start the truck. Is there an adjustment I can make on the clutch safety switch? Where is the clutch safety switch located?
Thanks,
Chris
Thanks,
Chris
Part Number?
What part numbers am I looking for?
Do I need to go to the dealer to get the parts?
Thanks,
Chris
I wish I could be of more help. I've never had to fix that problem myself but I have read a few threads about it. Maybe a few searches would turn up some help for you.
x2 on what Andy said but the switch is adjustable "in a way". ;)
Betcha you won't need to adjust it after fixing the wornout stuff tho! :)
...just like Andy said.
http://www.panix.com/~alvinj/file12/pushrods.jpg
See that middle pushrod and the wornout stud that went with it? :/
They are off my 188k '90 F250 parts truck.
I replaced the stud with a hunk of bolt and welded it to the crank.
The bolt was sized to fit the larger brake-pushrod to the right. :)
The brake-pushrod needed cutting off shorter and the end rounded...
http://www.panix.com/~alvinj/file12/pushrod.jpg
...that's just some careful grinding and a deburring wheel was used
to clean it up. :)
Seems to me all your parts can come from RockAuto and it's a real
good outfit too! :)
Alvin in AZ
to clean it up. :)
good outfit too! :)
Alvin in AZ
New parts
Just like Andy said.
good outfit too!
to clean it up.
Alvin in AZ
good outfit too!
to clean it up.
Alvin in AZ
Thanks,
Chris
Phil Fleming
06-21-2016 08:13 AM
IDIDieselJohn
11-26-2013 05:23 PM
Fordownsall
06-10-2011 09:40 PM
