Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-02-2010, 09:28 PM
rmalottwtes30's Avatar
rmalottwtes30 rmalottwtes30 is offline
Garage is empty, add now
rmalottwtes30 is gaining momentum as a positive member of FTE.
Gonna try running WVO
Whats the best way to filter this all out? Can I just use 5 gallon buckets and prefilter it with bedsheets, then after that what type of filtering should I do. I dont want to spend to much on this because I dont know if I am going to keep doing this or not, I just want to try it out first. Lets see your setups. I am going to run it at 80% Diesel and 20% WVO.
__________________
Ryan
1994 F350 7.3 IDIT
Dana 60
E4OD
  #2 (permalink)
Old 05-11-2010, 07:55 PM
kenjh's Avatar
kenjh kenjh is offline
kenjh is gaining momentum as a positive member of FTE.kenjh is gaining momentum as a positive member of FTE.
if you can find them ..furnace air filters work for getting the solids out just use a support underneath like a screen and if you warm it up it will flow faster ..the cheep filters work just fine ..are you seperating the vegge oil ..to remove the glyisern or going to try running it straight??
  #3 (permalink)
Old 05-12-2010, 08:56 AM
jimandmandy jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
Ladies panty hose. I saw this used on a PBS show about UVO in a diesel Mercedes. He ran 100%, but in Ventura, California where it never gets much below 50 degrees F.
Jim
  #4 (permalink)
Old 05-13-2010, 09:47 PM
Fordless Fordless is offline
Fordless is starting off with a positive reputation.
A guy I work with uses filter bags from Mc Master Carr to filter his veggie oil. He pours it thrugh a pool skimmer to catch the fries and chunks then a 25 micron to a 5 micron to a 1 micron @ 150 degrees. he uses 40% WVO to 60% diesel dumps right in tank of an 84 diesel Escort. His truck (00' 7.3L) uses 100% with a Golden fuels heated tank and heated filter. He has about 40k on this setup.
  #5 (permalink)
Old 05-13-2010, 10:49 PM
kenjh's Avatar
thats the big thing with veggie oil heating it up so it will move..but it will also eat the hoses from the inside over time..but not on all diesels there are veggie fuel forums that will share thier experiance with you ..always good to learn what dosen't work before you try..
Tags
73, ford, idi, systems, uvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
