alternator over charging?
That means the regulator isn't switching the alternator properly. Either the regulator is bad, or the regulator isn't properly grounded. To test the latter, run a jumper wire from one of the regulator mounting bolts to engine ground. If that doesn't improve the problem, inspect the wiring between the regulator and alternator. If neither of those items are at fault, replace the regulator.
Rose88racing
23
03-26-2016 07:49 AM
Fordbronco69
13
03-09-2010 03:08 AM
