2-Wheel to 4-Wheel conversion, using D-50
#151
Hey Leo, Just measured my front (rear) shaft from joint to joint and it's the exact same size as yours.
It's only a two wheel drive, I thought it would have to be shortened, once the transfer case was added.
My rear shaft that goes to the diff is 331/2 inches, but that one will not or should not have to be touched.
My truck is an "extended cab" 1996, your's say's club cab, thats not the 4 door version , is it?
#152
#153
#154
#155
#158
They're not the same, super cab long bed has a 155" wheelbase and on a crew cab short bed it's 152"
#159
I saw this project done one time and they cut the inner piece of the frame off the donor truck and welded it on the new truck. That took care of the "Y" piece you had to fabricate.
Just a thought for those that use this thread in the future.
Of course this is the ideal time to do the reverse shackle swap.
Thats exactly what I'll be doing on mine.
A notch at the bottom will, of course have to be made on the bottom of the frame rail, but i feel this "inner" piece will add more strength or I should say, the same strength as intended to support the front leaf section.
It will allow for better alighting for the shackle bolt as well and correct distance from the front of the frame, I believe.
#160
#162
thanks for the great pics. i am having trouble making sure that i have the axle in the right place. can you get a measurement from the front shackle bolt center to the front of the front cab mount? i need to go off a fixed point on the frame that wasnt moved in the conversion. ie: front cab mount.
#163
https://www.ford-trucks.com/forums/1...l#post11182013
I swapped a '94 F350 SRW Dana 60 into my '95 F350 2wd using a Reverse Shackle Kit.
#164
#165
