Radiator ?
Radiator ?
Hey guys, I just put in a new radiator I ordered from Summit. I put the new tranny lines on filled her up with antifreeze and started her up to fill up the radiator when I noticed that the tranny lines were leaking. I tightened them up as much as possible and they still leaked so then I even went as far as to put some teflon tape on them and they are still leaking. Any ideas on what I can do/use to stop this? Thanks in advance...
I was wondering about using washers, just didnt know if I could use rubber or if I needed brass ones.
It depends on what type of fitings you have, and let's hope what you have on both the tubing and in the radiator are compatable. Typically, they are flare and seat, like on brake lines. The flare on the tubing is designed to seal against the seat in the rad, and tightening the tube nut provides the pressure to create the seal. These are straight threads, like a nut and bolt, and no amount of tape will seal them. Only tapered thread pipe fittings will benefit from teflon tape.
So before we can give you any further advise on how to fix your problem, we need to know more about your application.
