Column Problem?
Column Problem?
The other day i was in a Mc Donalds drive through and my column just dropped and i lost all steering. I pick the column back up and it drove away with no power steering as it seemed. In a parking space i checked the pump and it was fine. Gear box is fine. iI start the truck back up and it works but steering is rough. Next day i try and turn the key and it is stuck but i can still get the truck on but its hard to turn the key. I pulled the plastics off the column and i found lots of old reciepts and air freshners from the origional owner. I pull them out and the steering problem is gone. But the key problem still is around. Any ideas?
The ign switch is bolted to the side of the coulmn under the dash. Try unplugging the electrical connector from it and see if the battery drain stops.
Do a search here for ignition lock actuator and you should get details of how the key switch connects down to the ign switch, something may be jamming it.
Bruners4
02-09-2015 11:53 PM
dwj
11-17-2003 03:33 PM
