M6606 on a 351?
on
Ideally the motor has to be built with forced induction in mind.. forged pistons and lower static compression, different cam profile, etc, but even an all stock truck motor will take around 5psi boost as long as detonation is kept to a minimum. I believe there was a kit to put a screw on these motors at one time.. though I'm sure it probably used a different model blower.
