Rapid THUD when taking off
What causes a rapid thud when taking off. It kind of feels like slack in the driveline. Some times there's two or three. I came across a thread here that described that as a slipping tranny, especially in only 1 gear. That's my case, in first gear. There's also a bit of a shudder when taking off, also. I was hoping it might be in the torque converter, as I'm planning on upgrading it in the future, anyway.
If that were the case, what does it mean in real terms.
Waye
Waye
Seems like every 40k miles my slip joint starts sticking. I end up having to re-grease it and everything is good for a while more. Sometimes if I tow a heavy load, it loosens up or something because the 'thud' goes away. Eventually it comes back though.
Could be your slip joint. Does it happen when you first start moving after each dead stop?
Not shure what year your truck is ive got a 2001 f350 and mine started somethang like you are explaning. And found out that the bolts to the full float axle were finger tight. Dont no how it happen but it was just the driver rear axle that was doing it tighen it up and retorqe to specications and good as new . Good luck
That's funny. Sounds like me yesterday. First drive after installing new tie rods and springs and I hear this weird rumbling... It was the old springs rolling around in the back of the truck!
I tried to order the XG-8 PTFE lubricant at my local ford dealership. He looked it up and sure enough that's what it's used for. Motorcraft doesn't stock it and one other source he uses doesn't either. What's a reasonable alternative. Give me specifec brands if you can please and where there sold.
Thanks,
Wayne
Thanks,
Wayne
I used Schaeffer's on mine.
Schaeffer Mfg. | Moly EP Multi Purpose Grease
I also installed two zerk fittings 180 degrees apart on the short section of the slip yolk. No more pulling the drive shaft to grease it, a few pumps every 6 months or so keeps it pretty quiet.
