1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
soft suspension cure
Old 04-02-2010, 07:21 PM
Hubnut's Avatar
Hubnut
Hubnut is offline
My 2006 SD 6.0 short box has a really soft suspension that I don't care for. I prefer a stiffer ride. If I go to a 2.5 or 4 inch lift kit (Icon is what I'm looking at from Truck Toyz performance) will it stiffen up the ride some? Truck kinda bounces too (I guess the shocks are shot?).
Old 04-03-2010, 11:54 AM
ReAX's Avatar
ReAX
ReAX is offline
The simple idea is the springs are the push to keep the axle and frame separate. The shocks are the ones responsible for the ride. Shocks control compression and rebound of the suspension. Compression rate is how fast the axle moves toward the frame, and rebound is how fast the spring is allowed to push the axle away from the frame. If the rebound is too fast, the tires slam back to the ground and push the frame up sharply. If the compression is too fast, it can feel a bit floaty.
Good shocks make all the difference in the world, and the biggest difference between shocks is the valving (the compression/rebound rates.) There is a science behind it.
Old 04-03-2010, 03:24 PM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
Icon lift springs are progressive rate, meaning the top of the spring basically can carry less, and the bottom of the spring is stiffer, so that equates to a soft ride unloaded, but a stiff ride when the suspension is all the way compressed. Look on your door tag, I'll bet you have 5200# or 5400# springs, go buy stock Ford 6000# or 7000# springs, and it'll change your front end feel. Yeah, shock do a lot, but with the weight of that diesel pushing down on, stiffer springs can carry the load better.
Old 04-03-2010, 06:12 PM
Hubnut's Avatar
Hubnut
Hubnut is offline
texastechd,
You are absolutely correct! I never thought of looking at the springs. They are 5200 just as you said. I bought the 2.5 inch kit anyway. I want a bit of lift and may go with some larger tires. I hope the new combination is a little stiffer anyway.
HN
Old 04-03-2010, 07:14 PM
Nick from Maine's Avatar
Nick from Maine
Nick from Maine is offline
I just put the 7,000lb springs in with a newton 2" leveling kit and truck rides way better and is level,had the 5,200 springs in and with a 9ft. plow it looked like a chevy when I lifted the plow,moved it out of garage today and it didnt move at all when I lifted it.got the springs from dealer for $187.00 took 2 of us about 3 hours to do the springs and leveling kit.
Rancho Suspension
Vendor Specials, Discounts, Product Announcements & Group Buys
07-26-2019 10:08 AM
ESank
12-25-2015 11:52 PM
cip57
12-25-2014 12:08 PM
mtgrzlyman
18
12-09-2014 11:01 PM
dieselsubmariner
07-14-2013 11:15 AM
Quick Reply: soft suspension cure
