dp mount
04-02-2010, 11:39 AM
on
dp mount
just wanted to know where the most common dp mount locations are, like where you mount the switcher? thanks
04-02-2010, 11:46 AM
Gauge switch or other switch?
04-02-2010, 01:37 PM
I have the F5 switcher and it is mounted with the bracket to my gauge pod. Very easily accessible there.
04-02-2010, 02:06 PM
on
I got mine here.I just drilled a hole for the cable and then used epoxy to hold it to the dash.
04-02-2010, 05:13 PM
on
chris i like your mount there by, the 4x4 switch! knowing me i would mess up. how does that pod attachment work? where did you run the wires trough the first pod?
04-02-2010, 06:43 PM
on
I mounted mine to the L of the steering wheel I hate it there! I may move it to R(4x4 switch area) seems ideal!
04-02-2010, 06:57 PM
Got mine here but I'm contimplating moving it to a gauge mount.
04-02-2010, 09:54 PM
Mine is just up and to the left in that flat area from where Mike has his. Works pretty well. It is only slightly obstructed from view for me. Just a slight head move to the right and there it is in plain sight.
04-02-2010, 10:22 PM
Funny as it sounds, where mines mounted, I can see the reflection of numbers on the switcher in my windshield glass at nite.
04-03-2010, 12:48 PM
i mounted mine in the dash here.
i am going to mount the heated mirror switch in the same place on the other side of the wheel.
04-03-2010, 03:32 PM
on
I got mine in the same place as tjtransport, works well for me.
Dan
04-03-2010, 06:47 PM
Quote:
Originally Posted by
tjc transport
Familiar theme!
Here's mine!
Stewart
04-04-2010, 06:43 AM
on
Hey Stewart and Tom, does the mount sit flush where you put it??
04-04-2010, 07:28 AM
got mine placed the same as Stewart's. does sit flush.
04-04-2010, 08:14 AM
yup.fits like ford put it there.
