wire loom tubes
Old 01-25-2003, 07:28 PM
41Clay's Avatar
41Clay
41Clay is offline
wire loom tubes
I was thinking about the early 21-A style wire loom tubes that run by the manifold and was thinking that little dudes create a good atmosphere for cross-fire. Has anyone had trouble with these things causing that? I like the way they smooth out the wires, but a smoother idle is much more important to me. Maybe the 6 volts didn't have a cross-fire problem but a 12 volt or electronic ignition may.
Clayton
Old 01-26-2003, 07:59 PM
mtflat's Avatar
mtflat
mtflat is offline
wire loom tubes
Clayt,
That shouldn't make any difference - the voltage to the coil is dropped by a resistor in a 12V system. Actual voltage across the points is only about 4.5v if I remember right.
Those wire looms do cause problems for some guys - mostly age deterioration of the wire's insulation from what I've heard.
Also a consideration is the firing order and how the wires touch each other. I've seen some crossfire trouble without the looms where 1/2 and 8/6 wires contact each other. firing order 15486372
On my '48 driver, I've even slipped plastic loom material between those wires that are prone to trouble. I don't like the look, but it sure saves headaches.
rebocardo
02-25-2021 09:16 AM
jv2290
22
04-19-2020 03:36 PM
Brett1989
1983 - 2012 Ranger & B-Series
09-25-2008 03:58 PM
nalts
11-11-2004 10:19 PM
Bigiron427
01-27-2003 03:57 PM
Quick Reply: wire loom tubes
