just did a 3g upgrade
#452
First start of truck after 3G install the belt was squealing and actually started smoking. I thought the alt was bad. I tripped the circuit breaker I have between the alt and the truck and started it up again. Not one little bit of squeal so I figured it was probably not bearings but load related. I checked to make sure I didn't have any wires out of sorts creating a short or excessive draw but no dice.
I was about to pull the alt for a test and thought I would do some reading and see if others were having problems with a squealing single v-belt. After some digging I found someone that suggested putting a touch of grease (I used dialectric) on the belt and run without a load for a few minutes. He stated it would help the belt settle deeper in the pulley. I thought to myself how counter-intuitive it is to grease something that is slipping but thought what the heck.
I put a small pea size spot of the grease on my finger tip and rubbed it on the belt areas that I could get to and ran it for a few without load. When I engaged the breaker you could tell there was a load but absolutely no squeal, slip or other odd behavior.
I guess there is significantly more drag on a high output alt. A single v-belt with the stock pulley off the old alt is probably the high end of what the belt can manage. I think some time in the future I will look for the two belt serpentine Ford setup in the salvage yard.
#454
My Alt squeals for about 10 seconds every time I start my truck. I haven't heard that trick with the grease before I will try it.
#456
There are cheap ones, if you aren't picky.
Powermaster Part pow112 - Chrome Pulley - - 4 Wheel Parts
Napa has some as well, but it took me a while to find a part number and that was years ago. E-bay is a source as well.
Just be sure that both belts go to rows on the crank pulley that are the same size or at least one of the belts will be slipping at all times, no matter how you lube or tighten them. Or...rather, however you decide to drive the belts, make sure they have the same ratio.
#458
Yea, and I have A/C so all three slots on the crank are in use, can't recall if i've ever seen a 4 slot, and re-aligning everything would be a PITA. That's why I was thinking the two belt serpentine setup, some adjustments needed but a donor vehicle should have everything.
#460
With a squealing belt check for unwanted initial draw .. Get in the habit of making sure all accessories are turned off .. Make sure you don't have something that is discharging the battery while the vehicle is sitting .. It may be never enough to notice because you start it frequently but certainly enough to discharge the battery to a point where on the next start up there is significant draw on the alternator ..
#461
I,v got dual v-belts on my 3g. V-belts should seat deeply into the groove rather than on top of it.
#462
#463
This thread is included in the tech thread compilation sticky of this forum:
https://www.ford-trucks.com/forums/1...l#post14213910
#464
#465
If the bolt is too long, trim it.
No separate ground wire....the alt grounds thru the case and mounting bolt.
