How to change coolant in the driveway
In the past I have been able to change the coolant in cars, without a big mess. But with the volume and numerous flush and fills to do the job right on there trucks. How do all you driveway mechanics do it without spilling half the coolant in the driveway causing the nabours from calling in the environmental people in. Any tricks tips or suggestion would help. There are probably many guys here that would change there own coolants if they could find a way from creating a big mess.
I guess this is one advantage to living in the country, I could change my coolant in the buff and nobody would know but me.
On a serious note, the biggest cause of the mess when changing coolant is when you remove the bottom hose to drain the system. If you use the drain plug it will take alot longer and probably wouldn't drain as well since the flow rate would be much slower but this would greatly reduce spillage.
I had decent results just putting a 5 gal bucket under the lower hose and carefully pulling it off. You have to do it a bunch of times, so you start getting pretty good at it. You'll get wet from the warm golden shower, but it only feels kinky the first couple of times.
I didn't do it in the buff, but after the first drain I did remove my shirt.
How long does it take before it stops draining from the petcock? About how much additional coolant drains when you then pull the lower hose?
It seems like this method may take longer to drain, but you might not have to wait as long for things to cool down because you have the added safety factor of the controlled flow from the petcock. Does that make sense?
I went to Wallyworld and bought a 30 inch long by 16 inch wide by 6 inch deep plastic storage box with a lid for around $4. It worked great. It is large enough in size to just put it under the lower hose and pull it off. Fills to about 75%. Put lid on and drag out to recycle. Worked even better than I hoped for.
Regards
Regards
