High Pressure Oil galley removal?????
Last week my truck ('05' 6.0 PS) died while under load. I already had a hot start issue and was getting ready to do thegalley seals. Anyway I did the air pressure test and found that the passenger side rear injector o-ring was blown out.
How do I remove this oil galley with that tube running out of the bottom of it??
The Haynes manual I have is pretty useless and seems to be made with the oil change and basic lube tech in mind. Is there a better manual available someplace?
Thanks.
Thanks.
Before you remove the rail, double check to make sure the oil is coming from the rail o-ring area and not the injector drain port it self. Also check the case-to-head tube area to make sure the leak isn't there either. You said it was the back injector. So you probably checked correctly.
After removal of the oil rail bolts, the case-to-head tube is just o-ringed on both ends. One end fits into the branch tube down below, and the other end fits into the adapter piece that is threaded into the oil rail (you can see the allen part on top that removes it from the rail). The tube is a 2 piece design with a long piece that just pushes into the branch tube and the adapter. The short piece (the thread in adapter), threads into the rail and does not require removal to remove the rail. The long piece is usually a bit tough to remove from the rail. Usually the long piece comes out of the branch tube before it comes out of the rail, but to remove the rail, it is easiest to remove the long piece from the rail first. If you have the rail off the injectors with the long piece still attached, try and get the long tube to pull out of the rail.
Inspect the o-ring o the injector to be sure it is the o-ring that is bad. I'm not sure if you can find that replacement o-ring.Others on the forum may know. If not, a new injector comes with one. The next most likely thing to leak is the injector itself, blowing oil pressure through it and not keeping the rail pressure up. That requires injector replacement. Another problem if the o-ring does not look damaged, is the puck that is threaded into the rail and connects the rail to the injector. Those have been known to leak, but much much less frequently.
Adam has it covered better than me--LOL. The top injector o-ring is now available from Alliant but is a biotch to change. Unless Ford has changed it the stand pipe must be changed when it is removed also----that is the long tube that sticks vertically in through the head.
Still sounds like an STC fitting to me.
on
on
thats going to be the oring under between the coil and body is my guess. check and see if the tops of the coil bolts are still there or if they broke off.
if they are missing you will need to try and find them before they make it threw the lpop.
that concern is normally ccaused by low fuel pressure. or so tech support claims.
I was just going to replace all the O-rings in there and go do the other side while I have it apart. Is there an o-ring kit for this? Someone mentioned having to replace the injectors because of the o-rings there. Is that true?
coil bolts???? I have no idea what those are. Are they located below the hp oil galley?
