Brake line replacement.
I have a 2000 F150
Vin# 1FTRX18L9YNB77328
I finished replacing the the line that runs along the frame. Now I need to replace both rear lines running from the to the Calipers. The part numbers are 2267 for the P/S and 2268 for the D/S.
I thought I could just bend some new lines but it appears the line from the calipers to the "T" it is one line steel and rubber. The ford print also shows the part numbers starting on each end. There is a clip between the rubber line and the steel line but I don't see any hex head fitting. This might indicate it's all one piece. The local dealer looked up the numbers and it said to improvise.
Any Ideas?
Any Ideas?
Chris DeLoache
09-20-2016 10:07 PM
annaleigh
15
11-11-2015 10:34 PM
annaleigh
10-25-2015 10:43 PM
