1960 F100 4X4 and 4X2 Leaf Springs
Old 11-13-2014, 09:02 PM
JPBrecheisen's Avatar
JPBrecheisen
JPBrecheisen is offline
Thanks for the reply and the advice. I figured I would get the "good luck" response. I know the early factory 4x4s are scarce enough, but then there are the parts....
I appreciate the tip on getting involved with some old truck clubs. I am subscribed to a few online forums dealing with old trucks and those connections and leads are always helpful.
For the time being, I will keep my eyes out for a set of factory brackets in order to try and save some of the fabrication effort. The brackets are repairable, but I would like to try and preserve the "factory" appearance which might be difficult when going the fabrication route.
Thanks again for the input and reply.
Jonathon
Old 11-13-2014, 09:19 PM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
Jonathon; Thats a good looking fridge!
You may want to contact some of these guys that are converting to CV front ends and entice them into knocking the rivets out of their brackets for fee. It would be interesting to see the differences between the 4x2 and the 4x4 brackets? Dark siders are not all bad.
Good luck in your quest!
Old 11-14-2014, 08:26 AM
JPBrecheisen
bracket search B9TT5340A
Thanks. I will keep on the alert for possible removals from update projects.
I don't know the difference between the brackets yet. I am still researching. Another mentioned they were different part number, but same dimensions. I would assume maybe they would be taller to make clearance for the pumpkin under the oil pan? I dunno.
Jonathon
Old 01-12-2015, 09:39 PM
ForLifeCo's Avatar
ForLifeCo
ForLifeCo is offline
Jonathon
JPB the brackets #B7C 5340-A for 2WD and #B9TT 5340-A for 4WD are the same bracket the only difference is the holes for the spring bolt. 7/16" for 2WD and 9/16" for 4WD.
Old 01-12-2015, 09:44 PM
ForLifeCo's Avatar
ForLifeCo
Jonathon
There are some NOS #B7C 5340-A out there but no B9TT's… I had a broken bracket and replaced it and drilled up the spring bolt holes.
Old 01-12-2015, 10:24 PM
JPBrecheisen
Thank you for this information!
I had no idea the only difference was the bolt hole size. I had gotten busy over last few weeks and had not gotten to the bottom of it yet. I will begin looking for both numbers. I know of a 2WD near by at a junk yard. I should go check that out as well.
Thanks again!
Old 01-13-2015, 03:56 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Just picked up a 1960 F250 factory 4x4. It is fairly complete and in restorable condition, but the front spring rear brackets are in bad shape.
Looks as though maybe the bushing went bad, then the springs rode directly on the bolt until the bolt got thin enough to fail. Looks like it was run like that for some time. It came off a farm, so there is bond to be some carnage I suppose.
I am looking for the 1959/60 F100/250 4WD Front Spring REAR brackets: B9TT-5340-A
No Ford dealer or obsolete parts vendor has any.
B7C-5340-A .. Front Spring REAR Hanger Bracket / Obsolete
Applications: 1957/60 F100/250 2WD
Four sources have 1 each. The following are the only sources with more than 1.
GREEN SALES CO. in Cincinnati OH has 3 = 800-543-4959.
HIGH BUCK! BOB ALLEN FORD in Overland Park KS has 3 = 800-676-0675.
Parts catalog pics = Left: 1959/60 F100/250 4WD / Right: 1957/60 F100/250 2WD
Old 02-19-2015, 10:53 PM
JPBrecheisen
Thank you for posting this. Sorry for the late reply. Work has been busy and I hadn't had much time to get on forums for project work.
I purchased two of the brackets from GREEN SALES. Got them in the mail a few weeks ago. Exact match except the spring eye bolt hole just as you all have said.
I do have a follow on question though. I am fairly certain the spring cap (5A316) is warped or bent to some degree. I recently splurged on a 3 book set of Ford Truck Parts catalogs but when I look up 5A316 in the text it only lists for '61?
Any help on a '60 application would be very appreciated.
Jonathon
Old 02-19-2015, 11:07 PM
JPBrecheisen
This is what I'm talking about. A pic of my book. I have the 57-63 Ford Parts books.
Jonathon
Old 02-20-2015, 07:50 AM
montego69's Avatar
montego69
montego69 is offline
When my leaf springs were rebuilt, the shop used a clip that just wrapped around the spring pack and folded back upon itself. In my opinion, any spring clip is fine unless you're looking at doing a concourse restoration.
Nick in WI
Old 02-20-2015, 03:39 PM
JPBrecheisen
Nick,
Thanks for the information. I appreciate it.
The part I'm actually having trouble with is the 5A316 which is the bracket that the U-Bolts go through and in-effect clamps the axle housing of the front axle to the bottom of the leaf spring.
I should have done a better job taking a picture of the book.
Thanks for chiming in as I know this was originally your thread.
Jonathon
Old 02-20-2015, 04:00 PM
montego69's Avatar
montego69
The 5330 which is part of the 5A316 assembly is the clamp that ties around the pack of springs. It doesn't do anything for bolting the axle to the spring assembly.
  #28
Old 02-20-2015, 07:07 PM
JPBrecheisen
I believe the spring pack clamp is a 5330 which is part of the spring 5310.
I see 5A316 as its own separate item and not inclusive to 5330.
Maybe I'm reading it wrong?
  #29
Old 02-21-2015, 09:59 AM
theodore/teddy
Refyred
Jonathan; Do you need the driver side or the passenger side? They are different sizes. the one for the DS has a hole spread of ~5" PS ~4". The part # stamped in the parts are--
DS== B9TT-5442-B
PS== B9TT-5A500-A
A quick web check found nothing for either number.
I know you're working on a 1960 and some changes were made to the front axle during the 60 period. But just thought this might help!
  #30
Old 02-21-2015, 04:35 PM
thundersnow70's Avatar
thundersnow70
thundersnow70 is offline
Don't be so quick to think the rear brackets are junk. I also have a 1960 f250 4x4 and the brackets from the factory look like they have been repaired on a farm. Mainly what looks like washers welded on the side of the bracket. That is factory ford 4x4 washer welding on the sides of the bracket from what I have seen.
Quick Reply: 1960 F100 4X4 and 4X2 Leaf Springs
