Pulled 3 codes
Pulled 3 codes
If someone could tell me what these are and if thet are bad that would be great. 1-PO475
2-PO720 oss sensor circuit fault
3-PO603
My overdrive light started flashing at me yesterday while plowing but it still shifted just fine. It started doing it after i put a aburn limited slip rear end in last summer, it only flashes when plowing or when the roads are really slushy. Also have a dptuner.
3-PO603
re
Yes the 475 will come up if you unplug the ebpv solenoid. The Oss sensor is on top of the transmission. You may just need to clean it. Never dealt with it. Here is pic of it out of Chris's Album. https://www.ford-trucks.com/user_gal...182600&width=0
Yea, I'd take the sensor out and try cleaning it, or just replace it. Seems like they're around $30 at Napa. You might also check out the VSS on the rear diff. If your issue started after some rear end work last year, I'd pull the VSS and see if the magnet isn't covered in gunk or something. Clean it up and see if that helps.
The other codes seem common with a DP Tuner. You might try cleaning the EBP tube to see if that helps the 0475. The 0603 just means you have a chip installed. It will always be there.
Blk04Snake
2017+ Super Duty
04-01-2017 12:45 PM
xaviar
06-07-2014 10:39 AM
GaryF629
1983 - 2012 Ranger & B-Series
06-04-2013 07:47 PM
reality_check
04-18-2013 11:31 PM
