6.4L F-350 looking for fuel help
You are the 1st that I have heard lost MPG
A friend that told me about this program also added 3 MPG and alot of power
So I am curios
Also who told you it would screw your motor up?
And what did they say would get screwed up?
Thanks
I had the programmer set on the 2nd setting.
It will add alot of power. The problem is it dumps alot of fuel in the exhaust, which in the long run will cause the regeneration to clug up and when you bring it to the dealer they will be able to tell that you had a programmer installed even if you take it out. This will void your warranty. I was told don't even waste your time installing any type of programmer.
I assume a programmer leans it at times
That is why some say it raises Temps and that can be when the problems begin
I have noticed less regens since I added the program
And the tips on the exhaust are much cleaner
There are a bunch on here that really know their stuff maybe they will join in...
By the way again who told you all of this????
Banks told me theres was not consider a programmer there was consider a tuner. It installs much different then a programmer. It plugs into several different ports under the hood as a programmer plugs into the port under the dash and all they do is dump fuel into the system. Banks does not dump fuel, it recalibrates the computer. For more info call Banks i'm not a mechanic, i'm just trying to figure out what I should do
