chip..chip..chipin away at it
#61
on
Heavy... chrome yellow..
Willie... we filled the rails with 'kitty hair" filler... with the final coat being short strand regular fiberglass filler... body man says he doesn't see where it would crack... that part of the truck sees very little flex so I'm hoping (we need a crossing fingers smiley)
We still have to dress the underside of the rail... had to do some no-so-expert welding to fix some bad places... got to cover up my work ! After filling and smoothing it should look much better than it does now... to me that is a highly noticeable location... it's one of the first things I see on a truck. I'm drawn to the seams and panel edges... crazy old man
later
John
later
John
#62
#63
on
hey Grizz..
I'd seen it before at the Supernats but saw two trucks at Cruzin the Coast this year that had it done... got to look at them real close and the more I looked the more I liked it... my rails were tired and needed a lot of work so filling seemed a reasonable solution... they are pretty much non functioning in an air conditioned vehicle anyway...
thought about removing them...but that's backing up a good bit... here's a pic of one in paint that was at the show...
later
j
later
j
#65
#66
Looking good John!! I was up in your neck of the woods this past Sunday visiting our Daughter. Even had lunch @ the Bright Star Restaurant in Bessemer. One of these days I'm going to make time to look you up and we can talk trucks (and grandchildren!) My '54 is finally @ the paint shop, so I'm shooting for the Supernationals, but more realistically Cruisin' the Coast 2012. Keep posting cause we all like pictures. Later, Steve
#67
on
You should have called Steve... I would have let you buy me lunch... Bright Star is good for lunch ($) dinner is ($$$$).
Sam...we discussed the profile and we both thought it would look better if we followed the contour of the roof more... see crude sketch... I bought some etching primer yesterday and am anxious to give it a light coat and see how it looks...
body man wants to get a day with sunshine to skim and block the roof... there are a few bumps and dips in it... soon...
j
j
#68
#69
on
euuuuu shiny !!!
last of the parts for the engine are loaded in the back of the 'burb' and headed to the builder in the early a.m.
exhaust manifolds and gaskets
oil pump drive shaft
flex plate
the ford racing valve covers finally arrived from Canada as did the air cleaner and breathers from e-bay dealer...
probably this week will button it all up... put it on the run-in stand and fire that puppy up... this is almost like a first date !!!
most likely won't happen this week.... headed to Panama City for the Emerald Coast Cruise in on Thursday... and already have more projects
that have to be finished before that... but soon....
thanks for letting me copy you Sam...although I'll never have one as nice as yours..
I promise when I get that big trophy at the supernats I'll give you a shout-out
shiny stuff follows.....
later
j
flex plate
later
j
#70
flex plate
later
j
flex plate
later
j
check the surface of the valve covers.. I had one that looked like something got dragged thru the chrome.. shiny snail track.. they replaced the one cover..
its beautiful stuff..
your chassis looks LOTS better than mine does.. wish I had used glass paint..
Sam
#73
#74
on
Sam... hmmmm maybe they put in a set of baffles for a sb ???
Bobby.... me too, bobby... me too... should know in a week or so when it comes home... once it's finished and run in... it will transfer to my engine stand for transport... then attach the trans... hang it on the hoist and drop it in... keep all the things that will cross... crossed..
BTW.... what is the going rate for a rebuild on a c-6 ??? it's been sitting dry for years and I'm sure it needs everything and a torque converter... add that to the list... and I need to drag it out and work it over with some coil cleaner and the pressure washer... then clear coat !
j
j
#75
Bobby.... me too, bobby... me too... should know in a week or so when it comes home... once it's finished and run in... it will transfer to my engine stand for transport... then attach the trans... hang it on the hoise and drop it in... keep all the things that will cross... crossed..
j
j
Sam
