Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Crossovers
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
  #1 (permalink)
Old 02-21-2010, 03:05 PM
thmitch79 thmitch79 is offline
Garage is empty, add now
thmitch79 is starting off with a positive reputation.
07 edge, grinding noise, any ideas?
Howdy,
I own an 07 Edge, AWD, 35K mi, had the PTU replaced so that SHOULDN'T be an issue but all of a sudden I have a grinding noise at highway speeds. I replaced front and rear rotors and pads, (both worn but normal wear) and the wheel bearings don't seem to be a problem. If I can fix it myself I will but I'm at a loss here. Any suggestions?
  #2 (permalink)
Old 05-03-2010, 10:15 AM
JonKala JonKala is offline
JonKala is starting off with a positive reputation.
Thats strange. I would check dust shields and retake the brakes apart and check it out.
  #3 (permalink)
and check the hubs!
  #4 (permalink)
Old 05-04-2010, 01:05 PM
ericautopart ericautopart is offline
Former Vendor
ericautopart is starting off with a positive reputation.
Center bearing on the drive shaft..unless that's what the PTU is but I didn't know what that meant.
  #5 (permalink)
Old 05-04-2010, 10:34 PM
NoMo's Avatar
NoMo NoMo is offline
NoMo is gaining momentum as a positive member of FTE.
The PTU is, I believe, the AWD equivalent of a transfer case.
From what I've read, people have had to have the PTU seal replaced multiple times due to leaks. You'd be well-served to check yours as it could have leaked again draining the fluid... leading to the grinding noises.
  #6 (permalink)
Old 07-18-2010, 07:10 AM
Noise found
You are NOT going to believe this. First, Thank you to all that responded, I haven't repiled as I just took a very long trip. Rust was the problem. Being in Upstate New York, that should have been easy to find! Pieces of rust where getting caught between the dust shield and the rotor on the pasenger side of the car, front and back. In fact, I had a squeal that drove me crazy and that was the dust shield on the rear passenger brake that just needed to be bent back with a screwdriver. Just goes to show, check the simple stuff first. Thanks again to all.
Tags
07, 2001, awd, edge, f150, ford, grinding, loss, mkx, noise, power, problems, ptu, scraping, sound, taurus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
