Radio won't turn on
I work with a guy who used to fix these things for Ford 20 years ago but he's
forgotten the specifics about this exact condition. In any event, yes, it can be
fixed, but you'd prolly be better off just buying another one (or two ;) from a
local junkyard. You already have the brackets to mount the thing in the truck,
THAT is the important part. The radios are sometimes in mid-80s high-end Ford,
Mercury & Lincoln sedans (LTD, Marquis, Continental, etc.).
fixed, but you'd prolly be better off just buying another one (or two from a
They can be made to work, I played around with one or two out of
Taurus-class cars.
Not really sure what you're referring to when you say "spring thing" but I have
an idea... are you talking about a large, flat thing that's underneath and that
kind of clips onto a metal ledge and thereby provides support from underneath?
You don't have to use that, just so long as you use some sort of rear
supporting mechanism. The older radios have a nut on the back onto which you
can attach a strap to hold the radio up. The straps are similar to the kind of
stuff used to hold up plumbing inside of houses - flexible metal with lots of
holes in it, just like below:
In any event, the newer radios (at least, the ones I played with) pretty
much suck from a sound output standpoint. Sure, they have more features
and more memory and whatnot, but they don't put out the same power that
the older ones do.
To add to that, while the wiring colors are pretty similar (the important ones
are the same) the connectors are entirely different, and you'll have to do
more investigation to find the correct speaker wiring.
BTW I know nothing about 8th or 9th 0r Nth gen, all I know is what I've
played with.
Taurus-class cars.
the older ones do.
played with.
Taurus-class cars.
the older ones do.
played with.
Taurus-class cars.
the older ones do.
played with.
I answered my own question on how they mount,the radios around 87-89 still mount with mounting plates,but they screw in on the sides,not the top and bottom like the 85 radio.If the plugs are different,then I'll just stick to looking for an 85-86 Radio.If I can't find nothing,then i'll have no choice other than to go out and find an aftermarket head unit.Thanks for the help guys.
But don't those require radio removal tools to pull them out?Or are they newer radios that mount in the same way as the 7th gens?
Alot of the radios interchange between cars and trucks.Sometimes the only difference is the sound package.But I still have limited options though,cause I need to get a radio that bolts into my truck the same way,because some of the newer radios(like the one in your mustang)might use the spring type fastening system,which my truck doesn't have.
icelander_34
11-26-2020 10:39 AM
Glenn Nall
04-19-2018 07:04 AM
tzanaglio
06-24-2011 08:38 AM
ford66
03-30-2010 01:53 PM
