53-56 F100 Tire and Wheel combo
I need some wheel and tire help. I have a 56 that has been dropped about 6" all around that is currently running 235/75R-15's on all corners. I have the stance where I want it and the 235/75 looks great from the side but from the *** end they look so small in the wheel well. The fenders are stock by the way. I have tried 255/75's and they do not look good at all. Any body have some advise? Pictures would be great. Thanks
If you want a fatter tire that's the same height as the 235/75, try a 255/70 or a 275/65. Here's a great link I like to play with to compare tire sizes.
Tire Size Calculator - Discount Tire Direct
In other words the diameter is ok but the width is too narrow. You have to be careful going too wide withthe tread out that far from the wheel. And you have to be careful to not make you r tread wider than the wheel rim. What width 15" wheel do you have on the back.
Here are a couple comparison charts that might help you calculate something the same height, but wider:
Tire Diameter And Circumference Calculator
U.S And Metric Tire Size Information Calculator
Shadowrider123
10-13-2013 10:10 PM
senty8
20
08-11-2010 09:24 PM
NitrousAl
08-21-2005 06:50 AM
