rim question
rim question
does anybody know or can you find out if the rims from a toyota fj cruiser will fit an 05 xlt f-150. I am not very good with finding stuff off the internet. I have found out that the wheels are 6x135 which is the same as my rims, but want to make sure they will work. If your wondering I can get a set of brand new trd rims with bfg all terrains for next to nothing, and I would be using these for nothing else than trail riding/offroading. Thanx in advance.
You'll need to find out more specs to know if they'll work. Is the center hole the same diameter? Is the back spacing and offset the same or close? Are they at least 17" wheels? Are the lug nut holes the same size and taper? If the price is cheap enough you might consider buying just for the tires and find a used set of Ford wheels to mount them on.
Flathead 51
19
11-28-2007 07:55 AM
