Fixing Chronic 390 Exhaust Manifold Leak
#32
on
I guess the real reason most all gaskets fail is not reading the instructions in the motor manual books. Plus they don't use the lock tab washer. Ford even used graphite high Temp grease with the "HEAT SHIELDS" Not gaskets. Once those lock tabs are left off the bolts work loose and you've got a leak again. My ex in laws have a 62 Merc. they got new. It's got 144,000 miles on it. The heads have never been off. And that 352 motor has never been apart or had any kind exh manifold leaks 53+ years they've owned and still driving it too this day. Ya got a use locking type bolts and heat shields or high temp rtv. Heat shields are just stamped out sheet metal a raised ridge to make a compressed thin steel seal.. Ford figured it out and tells how to do it, but no one follows what the books say.. Do right is doing it once..orich
#33
#34
on
Mac's sells A Kit includes 16 bolts with correct lower case letter f on the head, 16 locks and 16 flat washers. This kit does not include the special hook type lock used on the right side to hold the choke tube in place. Our 9A447-AST & 9A447-CST both include the correct hook type lock.
Ford Thunderbird Exhaust Manifold Bolt & Lock Washer Kit - 32 Pieces - 352 & 390 V-8 View More View Larger
PART # DESCRIPTION PRICE QTY
B8AE-557 Ford Thunderbird Exhaust Manifold Bolt & Lock Washer Kit - 32 Pieces - 352 & 390 V-8
Mac's sell these heat shields. but cheaper at auto zone and many other auto parts stores sell the Heat Shields Victory, fel pro, so on..orich
#35
#36
#37
#38
Virginia Classic Mustang lists the ramp-loks for factory cast iron headers as;
68 thru 70 428cj=EH-110
69 390 = EH-111
I mis-spoke earlier, old age. They are two piece. Hope this helps. As stated before, I've never had an exhaust leak using them.
69 390 = EH-111
JLuskin
08-26-2015 12:18 PM
stilkikin
03-05-2012 07:55 PM
