knocking under load....
#61
#62
#64
Also has stage 2 inj's and a chip.
Dont know the trucks pcm code. I dont recall
what tony would use for a base for the handshaker. (maybe same as auto TDE?)
My thoughts are he needs to get the oil temp up first.
Then move on.
Bill
Then move on.
Bill
#68
i won't be able to make it to check the sensor vs amb temps and IAT til i get the scan guage. the only time i have access to the solus is when i get off work on days i work early shift so the truck is warmed up from the hour drive over there.
Thank you Bill, Tim, Rick, and of course Rog for the intermission. LoL. y'all are a huge help. i still have a long way to go to get where y'all are. haha. So intermission til i get even more info!!!
#69
hey guys, i have been fiddling with the truck a bit here and there and have another question on this "knock". what are the chances this could be a bearing in the trans? it gets louder as you go faster. so in 2nd and 3rd gear you can't really hear it much. get it to 4th and it gets louder, then in 5th at cruising speed while on the pedal it will be a little louder than in 4th gear, but yet you let off and it stops. get on it hard and the "knock" will speed up a bit and get louder, but u let off and come back down to cruising speed and it quiets down again. also my shifter boot has a piece ripped off the corner and if you cover that spot up with something the sound quiets down so thats where i'm hearing the sound.
I still have to compare my EOT with ambient temps and my scan guage should be here soon so i will compare it at that time.
#71
#72
#73
The only time I have heard a motor knock under load ,was a bad main ,, maybe wrist pin ,( not often & only when cold )
May want to take a second look at the injectors ...Knocking may be a dry one (broken nozzle , spring ect) bla ,bla bla,,,
ran the buzz test and system passed, but at the start of the buzz test something doesn't sound right. sounds like one of the injectors buzzes then stops buzzing for a second then starts buzzing again and works fine.
#74
yeah you can feel a little tapping. i could feel it a little, but am still not exactly positive if it could be in the tranny, but my stepdad seemed quite positive that he could feel it a lot when i was at WOT in 4th and 5th gears. we were on back roads so i had him feel for it while i got on it and kept it on the road. LOL. seems to take a little while to do it once you start driving it. today it didn't start making much noise til i was almost home from work(about an hour drive) and i drive a mix of stop and go and highway driving coming home from work. i was less than a mile from home til it started getting loud again. i guess it's doing it more as the tranny heats up? the engine was warm long before it started getting loud and it gets louder with harder acceleration.
#75
I will run another CCT and buzz test when my scan guage gets here which hopefully will be any day now. i have another set of injectors here so i could always get Jim to send me a set(a little larger of course) and then send him my stage 1's back and pay him for whatever was wrong with them then he will have another set of machined IP's for a stage 1 kit. LoL.
ON EDIT: DANG IT!!! I NEVER DID FINISH SETTING UP A LONGER FUEL PRESSURE GUAGE!!!!! LoL. i will get back on that too. sorry bout that guys.
