change at home or pay for service?
FINALLY I CANNOT STRESS THIS ENOUGH MOST PLACE OVERTORQUE THE FLITER AND THE DRAINPLUG. Just thing hard steel overtorqued into soft aluminum again and again. Many new oil pans have been sold like this.
I do all my oil changes on all three of my vehicles myself...gives me an excuse to play with the tools in the garage. Also, I know exactly what oil is being put in and the filter being used. I don't have to worry about it being over filled or not enough put in. And I dump the oil for free at the local auto parts store. I've heard of some places not doing a good job like making sure the oil cap is placed back on or the drain plug is only finger tight. I can see them getting too distracted and forgetting something, less chance of that happening to me. And if you have to watch their every move because you don't trust them then you probably shouldn't be taking it to them. Plus if there's any mistakes I know who to blame...ME! Haha
OJ
OJ
Is it really even an option???
I have never actually heard of a "quicklube" forgetting to put a plug in or cap on?..Does that really happen???
Just kidding.....My honey knows a girl who's engine seized after leaving a "quicklube".
Not sure if they forgot to put the oil in or the plug in, but she said the engine had no oil.
Does it really matter what they did wrong?
Twice I have seen wheels almost fall off vehicles because lug nuts had only been finger tightened.
Blunders, coverups......and then they want to rob you blind......My a$$
Suffice it to say that only one person works on my truck.
Quick lubes suck. They don't care whether or not the job is done right. They are getting paid $10 an hour to do this... It's not a big concern for them.
I change my own oil in all 5 of my families vehicles. I know everything is done right, the best oil on the market is put in, and that the filter is properly installed. Never left screwed on wrong, or the plug not put in. I take care of my vehicles, and I don't care whether or not I got a warranty. Warranties are only there for the dealership to make money... so don't even worry about it.
I do all of my own vehicle maintenance and service, well 99.99% of it anyway. I only have someone else do the things that I can't, don't have the tools for (too expensive), or can't afford not to have done by someone else (alignments, tires, etc.). As far as oil changes, I use a motor flush with every oil change, quality oil and filter, and sometimes even an additive. I also check all the fluids, filters, spark-plugs, dist. cap and rotor, and lube everything at each oil change. So, as I see it, I'm spending the same as if I took it to a quick-lube, except I'm getting a much better job. I should also say that I was a mechanic/technician for some time before leaving the field to pursue another career. Oh, and I do still enjoy working on my vehicles at 50 also.
And one other thing, Our local dump accepts old oil, paint, batteries as well as trash and yard debris.
Back in the 1980's I owned a Nissan pick up, great truck. Well, it was time for an oil change and I usually took it to the dealer for the oil changes. I decided to try a quick lube in my area this time. Oil changed in 10-15 minutes and away I go. It's oil change time again, so I return to the quick lube place. The manager comes to me and said who is the #$%@ who changed your oil last time? We can't get the drain plug off. I said you folks did. This guy looked at me like I was crazy even after showing him the last oil change paperwork from his shop. Well, they were able to get the oil drain plug off and replaced it.
I do my own oil changes on my Ford Powerstroke so I know its done the right way.
On my Bronco, I do all the fluid changes on it. On my Ram, I have free oil changes that were given to me by the dealership and I've never had issue with trusting their service. Once they run out, I'll do them myself. I do all the other fluid changes on the Ram myself only because I don't like how they simply just suck it out and refill. TO do my Diffs, I remove the cover so I can make certain the LSD is in good working order and no metal bits are visible. For the wife's Escape, well, if she wants the oil changed, she can take it in herself. It's a personal thing for me. I have no love for that vehicle and she was given a bad deal by that dealership and I think I, myself, have only been in it 6 ties in the 2 years she's owned it. It's not the vehicle itself, it's the way it was purchased and how we were done by the dealership. I could care less what happens to it.
My Ram and Bronco, I plan to keep until I can no longer drive. Being that I am from Florida that would be probably 50 years from now. On my 90th Birthday.......
Maybe 60 years if I'm lucky.....
#30
This is all true,
I used to work at a quick lube type place. That is all we did. We made about $8 an hour, Did as many as we could do. One time, We had to transfer 55 gallons of Rotella to anouther store and the individual who began pumping what was suppoesed to be Rotella 15w-40 was actually pumping Penzoil 5w-20. After about 10 gallons realised his mistake and just switched guns leaving the Penzoil in there. They would also smoke marijuana in the "pit" when no vehicles were in or anyone was around. Or how you would pay for a transmission flush and all that would happen is lower bay drains the pan and then upper bay would run ATF through the tube until about a quart drains out of the pan, once it does the plug goes back on and then it gets re-filled. Or a power steering "flush" would be just suck the "old" fluid out, Bad or not and put transmission fluid in. Sometimes on vehicles they knew would'nt take that, Did we use actual fluid. The place and people that would go there are a joke. Had a cop's daughter come in one day, The "crew" did the oil change and I vaccumed, (It was manditory unless not wanted.) Once she left about 20 minutes later manager gets a call from the "Father". He said we did'nt vaccum out her vehicle and I mentioned I did it and I made sure it was done although she had personal property that I would not touch. Vehicle came back and and sure enough it was vaccumed but her shoes were what I did'nt touch among something else I can't mention here we're right where I left them. He moved them, Actualy threw them he was so "upset" and under them was not vaccumed. And the manager agreed with me on the issue. But to feel important and how we knew he was a cop is, He pulled up off duty in civilian clothes in his city police cruiser. Or how some guy tryed to leave a loaded weapon in his mustang.....Or the woman who tried to kill her new chrysler hi-performance 300 by putting oil in the intake right infront of us then try to blame us for it, The list goes on forever...
