heater in fuel filter bowl?
Is there a heater in the fuel filter bowl on these trucks? I know in my 99 - 02 shop book there is one in there bowls. I'm thinking my starting problem is not glow plugs but cold fuel. If there is do they just sell the heater? When I changed my fuel filter there was a peace opf steel with what looked to the a wire soilder to it at one point. Broke free! I think it was part of the heater. Hope I can just replace that.
-Doug
-Doug
Yes, there is a heater and they do usually break. The wires come off and then short to the bowl and pop a fuse. Most people just disconnect the wire and leave it alone. I don't think it's an issue if you get winterized fuel. I think I saw a part # for the heater kit, but I don't remember where. I'm sure someone will be able to provide that info.
Red
Red
If you really want one :
Fuel Heater Element;
(Ford) F5TZ-9J294-A (94-97)
(International) 1825186C91 (94-97)
(Ford) F81Z-9J294-AA (98-02) Heavy duty, Can be made to fit 94-97, (International) 1831196C92 (98-02) Heavy duty, Can be made to fit 94-97
The stand pipe in the bowl is left hand thread ...
change it and then reply
Read this
Starting Cold Diesel Engines and use some anti gel in the fuel. your choice but if your in a cold area drop the CP's
http://www.chevron.com/prodserv/NewOronite/library/li_viscosity_motoroil.htm
http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil_Drive_Clean_Oils.asp
https://dallnd6.dal.mobil.com/GIS/MobilPDS.nsf/26b7c4b33367a4a086256665004e4266/61638dff7d0453b085256b8400618b40?OpenDocument
dooleyservices
12-28-2011 03:37 PM
Brown Falcon
34
03-26-2011 09:42 PM
YoungFordAddict66
12-07-2010 09:23 AM
1825186c91, 1831196c92, 73, 94, 99, f350, f81z9j294aa, filter, ford, fuel, heater, international, ohio, parts, short
