In the middle of a brake job...
And I know this sounds stupid, but where the hell does the zero-drag spring go? I assume that's the coiled spring thingy that's not the housing spring, right? I can't for the life of me figure out where it goes. If somebody could point me to a diagram it would be most helpful. If not, just tell me--I might be able to figure it out...
You didn't specify a year or if it's an Expi or Navi, so hopefully you get your answer here:
http://ww2.justanswer.com/uploads/fo..._160149_A1.pdf
http://ww2.justanswer.com/uploads/fo..._150619_A1.pdf
How do you replace front disc brakes on a 4 whee... - JustAnswer
Accepted Answer
You will see a slot in the pad which goes on the caliper piston side. One end of the spring goes there and the other is weged against the center of the caliper between the pistons. If you're using aftermarket pads then this slot in the pad may not be there and this is the reason it seems impossible.
Accepted Answer
OK--found the little hole in the brake pad and wedged that spring in there and against the caliper. Doesn't seem to fit real well, but it'll have to do. Don't think there was one there on the old caliper, so it's probably better than nothing.
Thanks alloro. I reckon I'll find out if I did it right tomorrow
Installed zero-drag spring
Hey guys, thanks for the info. It was very sparse on the net, so I uploaded a couple of images for posterity:
You'll note the little tab on the back of the piston-side pad with a hole in it. You put the straight side of the spring into that, then bend the side with the large bends in it until it slips into a hole provided on the caliper. It's easy, but hard to decipher from what was available.
