62 Ranchero no spark
Hey there new to the forum.
Have a 62 Rnchero 170 6 cyl. Started running like crap and then changed cap, rotor,plugs, wires and points. NOw there is no spark. Leaning towards balast resistor wire or coil. Have not gotten there yet. Also if anyone has specs ie; point gap, timing thanks in advance.
Have your wife hold the coil wire in one hand and to hold onto the negative battery terminal with the other. then crank it over. If she says she wants a divorce, your coil is good,
Sorry I couldn't resist. The other guys have given some good advice. Where did you buy your parts? I have bought ignition parts from advance before and had the rub block on the points fall off. Which caused a backfire that blew my muffler apart. Only buy my points from NAPA since
tjs_79ford
09-20-2009 11:30 AM
WA62F100
04-20-2000 11:18 PM
