1993 F150 302 e4od stalls in reverse and runs rich
Old 01-26-2010, 07:23 PM
mackdog's Avatar
mackdog
mackdog is offline
Question 1993 F150 302 e4od stalls in reverse and runs rich
since replacing the front fuel pump and o2 sensor, and ajusting the screw on the throttel body to raise the RPMs. the truck now stays running. The engine does not stall in drive but it does stutter almost like its going to stall and its worse when shifted in reverse espically when the engine get warm. When driving the transmission shifts hard going from 1st to 2nd gear and stutters in 3rd going to 4th gear and wont willingly change gears so I have to step on the gas to increase the speed before it will shift properly. I did a full tune up and change the transmission fluid and filter cleaned the throttle body and IAC. Also checked the codes and came up with 621-629- with the engine off and 538-536-632- with the engine running... I just cant figure it out
Old 01-26-2010, 07:55 PM
pro70golfer14's Avatar
pro70golfer14
pro70golfer14 is offline
Since both of them codes come back to soleniod body failure, I would look at that first. Bad, thing is that you cant find out if its bad unless you just replace it and see if it is fixed, and they are 100-115 dollars. Good thing is I thought I had a spare one around my house somewhere, if I can find it i will send it to you for cheap. But that is just what the codes are pointing towards. Don't know much more then that.
Old 01-28-2010, 06:57 PM
mackdog's Avatar
mackdog
mackdog is offline
still cant figure this one out, could it be a fuel pressure regulator?
kendogg
11-22-2023 05:07 AM
doc54321
2004 - 2008 F150
18
09-23-2015 12:33 AM
coach2live
03-23-2015 04:45 PM
ReluctantMechanic
08-29-2014 04:03 PM
Jesser02EX
06-05-2013 10:47 PM
Quick Reply: 1993 F150 302 e4od stalls in reverse and runs rich
