Info on title information.
I posted earlier this month on buying a Lincoln LS.
I found a gem online and called for information and received little feedback.
2005 Lincoln LS V8
So I went to carfax, paid the 40 bucks which I regret because i had a feeling something was up.
Turns out the car is a total loss vehicle, has a salvage title, and a flood damage title. What does this all mean? If you looked at the link I provided it looks like a clean car inside and out. The carfax stated that the accident was in the left front and was severe so it couldn't be driven away. The car looks fine, do I take my chance and go take a look at this car that is over an hour away from where I'm at, what do I look for? It's a nice looking car that has been maintained pretty well according to the carfax history report and it's from Virginia.
Any help out there please?
2005 Lincoln LS V8
If you want to satisfy your curiousity
- Check the dealer out on the Better Business Bureau website
- no record would probably be bad
- poor record would obviously be bad
- If they seem reputable, then ask them about the title. They should have mentioned the type of title in the ad. At the very least, they should be willing to say why they think it's worth anything.
Generally, I've heard that flood vehicles are poor risks. The water just does too much damage.
Major rebuilds are more iffy. A good shop can fix a lot of stuff. However, a bad shop can cover up a lot of stuff.
Maybe the carfax is wrong, but probably the $40 saved you a few $k.
I may stop by on my way to a doctor's appointment to check it out. I'll check it out and use my best judgement on the damage but I'm far from an expert on electrical components. I would have jumped on this deal in a heartbeat if it didn't have a bad rep. But the BBB gave the car dealer a B+.
Looking at other cars from the inventory on their web-sites I'm just guessing that a lot of them have the same kind of title. There are Cadillacs with less than 50k miles selling for less than 10k. Same scenario here, definitely not going to look into this car now.
Received 3,107 Likes
on
if it is like a lot of smaller used car lots, it is a consignment car. the cars get loaded on a semi and spend a few months at the lot. if it don't sell there, it gets loaded up and shipped to another lot.
a car that had a bad enough hit to be salvaged means it had at least 40% of book value repair costs. as was said, if it was repaired by a good shop, there is nothing to worry about. but there are many many shops that do a halfassed job, and hide things with bondo, seam sealer, and sometimes plain old house window caulk and then paint over it.
add to that the flood salvage, and i would run away from that car.
water damage does all kinds of weird things to computers and electrical connections.
not to mention mold spores hiding in the AC/heat vents, carpets and seats just waiting to be activated.
Does the CARFAX actually say flood damage...or...does it say that it comes from a flood prone area??? A few years ago that branding was added to the reports...not necessarily the title if it hasn't actually been under water to some degree.
For a salvage title due to body damage...50% of average retail is about the going rate.
If the car has indeed been in a flood...take everyone's advice and run the other way.
on
That's one way to look at it. But I would say instead that that was perhaps the best $40 you ever spent. A lot better than just following your gut. Plus, you still have the rest of the month to check out other cars.
Extremely unlikely. VINs have a check digit in them and if you make a mistake in the VIN it won't decode.
If a deal seems to good to be true it probably is. Sounds like this one is no exception. You are smart to stay away from this vehicle. Find one with a clean title and a good history and it will last you a long time.
