2003 5.4 expadtion no fuel pressure
Thanks for sharing the photos and details of your repair.
It's not serviceable for the typical shop or DIYer because the shop won't take the time (probably also lacks the expertise) to do component-level circuit board repair and DIYers are few and far between with the skills and equipment to do them. As it happens, you have both (as do I and a few other members here), but we're the exceptions.
For motivated DIYers who do not have the level of expertise you've exhibited, it's not at all difficult to simply splice a common Bosch-style relay into the external wiring to bypass the failed relay.
I don't understand why this is thought not to be serviceable.
Appreciate the comment but don't feel I am that good, I have seen an excellent video of a guy diagnosing this problem with a volt meter and a pressure gauge.
He hooks up to green / yellow wire on 4 pin connector, He contends that voltage drops first at the fuse box and then fuel pressure drops after. I found this reasonable. My vehicle usually did not throw codes but sometimes when it would die it would throw a lean code or 2 which is about useless. For the do it your self person with limited experience I believe taking an 8, 10, and 11 mm socket and a screwdriver to unhook the battery and remove the box to physically inspect the relay is not a huge stretch as long as pictures are taken for reassembly of the fuses and the metal clips on the board. The good thing is that Ford made all of the connectors different sizes. It should be remembered that each clip has a locking mechanism that must be released and the power lead has a removable cover that will need to be removed. If you are uncomfortable soldering relays maybe a trip to electronic repair or phone repair with the new relay might be reasonable. I was uncomfortable sending my board out to Ebay vendors in case it got lost and could not afford the new board. I have to admit when I put power back to the box it made me quite nervous. In my mind I could see smoke pouring out if I had screwed up.
Seems I was dropping around 1.5 volts between the alternator frame and the negative battery post. Narrowed it down to between the alternator frame and the engine block. I just made up a 4-gauge wire and ran it from the alternator frame to the engine block. Battery now reads 14.2 volts all day long (instead of 12.7 volts) and when its really cold here in Upstate NY it'll read 14.8 volts for a few minutes.
(And it really wakes up the ignition system. )
If I measured my circuit correctly the pump draws 15A.
Also, it is a motor so there is a higher tendency for arcing when the circuit is opened.
And for every time the car is started the pump is powered/turned off twice.
A higher capacity, easily serviced relay can be added fairly easily.
I mounted a 40A rated relay above the inertia switch next to the glove box.
The OEM relay output going to the inertia switch can be used to trigger the 40A relay.
The 40A relay output is then connected back to the inertia switch.
A new direct to battery feed line is needed for the 40A relay with a 20A fuse.
Now the OEM relay has .2A going thru the contacts instead of 15A.
You would think so but plug-ins have their own issues such as the socket contacts loosening up, generating heat, and then melting the relay. IMO, the best design is a separate pigtail with a relay socket on it. That way if the socket fails you can change a $5 socket instead of a $300 fuse box, not to mention the labor saved. But the chances of any engineer listening to any one of us is remote, at best.
Another repair approach given we are stuck with the "relay on a board" design would be to unsolder the original relay. Then take a relay socket with pigtail, solder the 5 wires onto the board and run the pigtail outside the fuse box. Did this with a washing machine.
Hello all,
Let me first start off by saying I am a capable mechanic, I own a fuel pressure gauge, scan tool and a nice box of tools. I'm no ASE certified mechanic, but I can fix most anything without to much trouble. I have replaced plenty of fuel pumps, brakes, engines, transmissions, even rebuilt carbs on really old junk. It's enough to last me a lifetime and because of that, I am the family mechanic. I have searched these forums along with other Ford forums, have found similar problems, but no real solutions to mine. That said, here is my problem -
My brother-in-law Dan has a 2003 Expedition with the 5.4 triton, 4wd auto trans and it has a cable operated throttle body. He started it Friday morning, it ran for a minute or so, sputtered and died. After cranking on it a few times, I had him listen to the tank while key was turned on and he could not hear the pump. Told him I would be over Sat morning to check it out.
Sat morning, put the fuel pressure gauge on it, cycled the key several times and got 0 psi. Cranked engine over 3 times - 0 psi. Checked the inertia switch, 0 psi. Went to check the relay and fuse and got confused. There is no Power Distribution Box under the hood!? No bank of relays, nothing. Got out the owners manual and it showed there is only a fuse/relay center behind the right front kick panel. Found the relay / fuse list and diagram for the box. List showed R303 is fuel pump relay. Right on! But, box only goes to R203!? Checked list in book again, R303 is fuel pump relay, looked at box and diagram, no R303 in the box, only goes to R203!?!
Dan had bought the fuel pump and fuel filter Friday so I said "good place to start." With almost a 1/2 tank of fuel I was really looking forward to replaceing the pump! Replaced both items, turned the key, no pump noise and 0 psi. cranked engine a couple of times - 0 psi. Check inertia switch again, no pump noise - 0 psi, swapped relays and checked all fuses in box behind kick panel - 0 psi again. Checked PATS system by turning on key, theft light went out after a few seconds and odo read mileage, 0 psi. Cycled key several times, no noise and still 0 psi!
Here are my questions -
1. Where is R303? There are no relays under the hood that I can find and it is not in the box under the kick panel. Is it in a super secret hiding place?
2. If the anti-theft light goes out and the odo reads normal, is the key still suspect? He only has one key. Is a spare key a Ford item?
3. If a sensor or control module fails on the engine, will that cause the PCM to not call for fuel and leave the pump off?
4. Is there such a thing called something like "Fuel Pressure Control Module"? If so, where is it and is it suspect? Will the scan tool see the problem if defective or does it need to be tested by other method.
5. Is the PCM suspect?
This fuel system has a supply and return line, but does not have a vacuum operated pressure regulator. It has something that looks like a pressure regulator on the rail, but no vacuum line on it nor a place for one. There is another regulating looking device on the fuel pump unit itself too. It is inside the tank once pump is in place.
Sunday morning I plan on checking codes, breaking out the volt meter and checking for power at inertia switch and fuel pump along with any other ideas I may get here. Hopefully I will find the elusive R303 relay.
I have a Haynes manual for it, well you know, it's not really "for it". It covers 98-03 and everything in it is the older systems with statements like "newer systems similar". Yeah, right. The only thing similar with the 03 and the older trucks is they both use gas and oil. Nothing on this '03 looks like the piks in that book so I have deemed it worthless for this job. Any help and advice is greatly appreciated.
Gary
Gary
it's a nonservicable relay. Inside the fuse/relay box. Fix is to get another fuse box
There are several options to fix this issue.
The CJB (fuse box) is no longer available new, so any used unit is going to have a used relay in it, too.
There was someone on ebay that used to service fuse boxes - send it to them, new relay installed, returned.
If you're handy the relay can be replaced, the relays are available.
Both, of these methods require removing the fuse box.
An external relay can be added without removing the fuse box, but again, need to handy with wiring.
Work Around
Found a potential work around by wiring in an external relay....will let y'all know how it goes tomorrow. Instructions were simple; terminals listed below:
85: Connect to a wire that is hot only when key is on (Pin 3 of connection C270B/Tan & Red Wire)
86: Connect to Chassis Ground
87: Cut Dark Green/Yellow wire from 4 pin connector (goes from circuit board relay to FP). Connect 87 to the outbound wire. (leave a few inches in case you F up and need to re splice the original back together)
30: Connect to bolt at incoming power connection to fuse block (its at the bottom underneath the cover). Between the incoming power and the relay, splice in 30A inline fuse.
All told, some 14g wire, 14-16g male and female connectors and T splices...If it goes well, I'll update....If the guy who charged me $50 to diagnose the problem as a faulty fuel pump is reading this, THANKS! It was fun dropping the tank with 20 gallons of gas in it IN THE RAIN!!!!! (joke's on you; it really WAS fun!)
30: Connect to bolt at incoming power connection to fuse block (its at the bottom underneath the cover). Between the incoming power and the relay, splice in 30A inline fuse.....
OEM: When the ignition switch is turned from OFF to RUN the PCM will enable the fuel pump relay for 2-3 sec to prime the fuel rails, then shut it off until it sees START or the Crankshaft Sensor spinning, not sure exactly what the logic is in the PCM.
That will be a continuous 15A draw whenever the Ignition Switch is in RUN and the engine is not running.
The PCM logic then keeps the pump running with the switch in RUN, until the ignition switch goes to OFF or the Crankshaft Sensor stops spinning, again not sure about the PCM logic.
From a safety view I would guess the PCM will turn off the fuel pump if the Crankshaft Sensor stops and the ignition switch is still in RUN, which could happen in an accident, but in that case the Inertia Switch hopefully will do its thing, too.
I like the power connection at the battery wire (RD) post at the fuse box, definitely add the fuse or a marine breaker, 20A or 25A would work, too. OEM is 20A.
I haven't had that apart before and didn't know that's how the battery was connected to a fuse panel.
The 4 ga RD battery wire does not have a fusible link in it, I'm going to add a 150A marine breaker to ours near the battery.
You didn't say what size relay you used, I used a 40A rated relay in ours.
#29
[FON
M
Gary man
[/FONT]
M
Gary man
[/FONT]
#30
