1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Craigslist 4x4 unibody?
Old 01-24-2010, 05:07 PM
unibody62's Avatar
unibody62
unibody62 is offline
This unibody is on craigslist. Did Ford even make a unibody 4x4? I bet it's a transplant.
1962 Ford F-100 Unicab Shortbed 4x4
Old 01-24-2010, 06:15 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by unibody62
This unibody is on craigslist. Did Ford even make a unibody 4x4? No. I bet it's a transplant.
NOT Genuine Ford.
It's something a previous owner put together. The EZ way to tell is: This 4WD truck has 2WD front fenders.
1961/65 F100/250 & 1966 F250 4WD's use different front fenders than 2WD's.
The 4WD fenders have a larger opening radius: 45" compared to the 2WD fenders that have a 36" opening radius.
When these trucks are converted to 4WD, they have to be lifted up for additional clearance.
1966 F100 4WD's use 2WD front fenders because these trucks were lifted at the factory.
Old 01-25-2010, 01:07 PM
unibody62's Avatar
unibody62
[QUOTE=NumberDummy;8415004]NOT Genuine Ford.
Interesting observation. I guess I've never seen the wider openings. It seems like it would be hard to notice from the pictures posted.... not close enough for me. I'll have to try to find a true 4wd to compare.
Old 01-25-2010, 01:40 PM
cobraguy's Avatar
cobraguy
cobraguy is offline
Ford NEVER made a "production" 4X4 unibody.
Old 01-25-2010, 05:54 PM
garbz2's Avatar
garbz2
garbz2 is offline
You can also notice the front axle is wider with the same rims front and back.
Old 01-25-2010, 06:12 PM
Back265's Avatar
Back265
Back265 is offline
Isn't the price kinda high? If there is not a trany or transfer case ..... factory 4x4 with matching gears. No motor, transmission or transfer case. .... what gears is he referring to?
Old 01-25-2010, 06:35 PM
NumberDummy
C2TZ16005D .. R/Front Fender // C2TZ16006D .. L/Front Fender / 45" Opening Radius
Fits: 1961/65 F100/250 4WD / 1961/66 F350 / 1966 F250 4WD.
Looking at the right or left side of the truck...compare the opening radius of the 2WD fenders to the 4WD/F350 fenders where they meet the doors.
The difference is very apparent.
Originally Posted by Back265
What gears is he refering to?
The ring & pinion gears. The front driving axle and the rear axle ratios match.
Old 01-25-2010, 06:58 PM
garbz2's Avatar
garbz2
garbz2 is offline
Well almost match. a ford factory will be 4.10 rear and 4.09 front.
Why I dunno....
Garbz
Old 01-25-2010, 07:03 PM
Old_Crow's Avatar
Old_Crow
Old_Crow is offline
Garbz, the difference in the ratios is to allow the front end to pull just a little bit more than the rear for directional stability. Also one of the reasons you're not supposed to run in 4wd on clean dry roads.
Old 01-25-2010, 07:06 PM
garbz2's Avatar
garbz2
garbz2 is offline
I was playing dumb......But great info. It also allows the front to track at a slightly faster speed in turn just like a regular 2 wheel drive, due to shorter radius.
Garbz
Curated Content Editor
General Automotive Discussion
08-17-2017 08:30 PM
664x4drvr
01-12-2016 06:27 PM
svolpone
08-24-2015 01:51 PM
RocketMonkey28
01-22-2010 05:45 PM
jasonst
22
01-08-2010 12:21 AM
Quick Reply: Craigslist 4x4 unibody?
