to those with 12.5 wide tires on factory rims
Old 01-20-2010, 10:09 PM
GwarForAll1021's Avatar
GwarForAll1021
GwarForAll1021 is offline
i had a dealer refuse to order me a set of 325 65 18 tires cuz he says its unsafe to put a 12.5 tire on a 7 inch wide rim.
i know i can find another dealer who dont care about my well being and does care about cold hard cash
i know some of you have done just this. whats your thoughts? i cant see it as an safety issue but more of a ware issue.
im not paying 600 more bucks to buy 10 inch wide rims so i can worry about back spacing and ask another tire size question that has already asked a million times.
Old 01-20-2010, 11:22 PM
greenmachine53's Avatar
greenmachine53
greenmachine53 is offline
I work at a dealership and do most of the tire sales, I would refuse that job also. I would look around and find some wheels or buy a little smaller tire. Just my $0.02
Old 01-21-2010, 02:02 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
if you have stock rims...they are 7.5" wide. not 7" wide. it's stamped on the inner lip of the rim.
if you have 20" factory rims, they are 8.5" wide.
have you considered a 305 width tire? you will run into a few less issues, and can get almost the same height
Old 01-21-2010, 02:49 PM
GwarForAll1021
i have tryed ... it seems like nobody in my town carry a 33-34 12.5 with an 18 inch rim. 17's tons of options. 18's its 275 or 325. i can get a BFGKO in any size but im so over them.
Old 01-21-2010, 05:42 PM
baitmaster's Avatar
baitmaster
baitmaster is offline
wear issues
Yrs ago I wanted the 33X12.50's on my old Ford with stock rims. The tire guy said I would have wear probs being that the beads would be pulled so far in, thus distorting the tire track. So I bought some wider rims, and that was that.
Old 01-21-2010, 06:41 PM
BatteriesNotINCL's Avatar
BatteriesNotINCL
BatteriesNotINCL is offline
i bought and had my tires installed at Discount Tire..
Old 01-21-2010, 09:27 PM
bigyeller's Avatar
bigyeller
bigyeller is offline
I am currently running 35x12.5x17 discoverer stt's on my stock 17" rims on my f150. I have no wear problems or ride issues. Previously i was running 305x65x17 procomp extreme a/t's and didn't have any problems with them either.
Old 01-21-2010, 10:12 PM
GwarForAll1021
no problems with safety? wear?
stt's is exactly what i was getting prices for. the dude preached to me for an half hour how its not going to work.
im so over it lol
Old 01-22-2010, 02:44 AM
tbear853's Avatar
tbear853
tbear853 is offline
Received 1,298 Likes on 1,098 Posts
A 325/65-18 is recommended for use on at least a 9" -- 10" wide wheel. Just what the charts say. I know they'll fit narrower wheels (I have a aged 31/10.50-15 on a 6" wide wheel for a spare in my '77, but it bulges a lot, I wouldn't run it far.), but the'll bulge a lot.
Look close inside the front wheel well and see how close your stock 275/65-18 tire's (recommended for a 7.5" -- 9.5" rim) sidewall comes to things like spindle or frame both straight and turned. On your 7.5" rims, your tires are about 10.8" across at the widest point of the sidewalls. These bigger tires are nearly 2" wider at 12.79", though that's on a 9" rim. I'ld allow at least an inch on the inside though, to be safe. Also, that widest point will be further from the rim.
Know any buddies who work tire shop? Maybe have a 325/65-18 to try on that front end?
Also, your speedo will read only 55.5 at a true 60 mph.
Last edited by tbear853; 01-22-2010 at 07:15 PM. Reason: it was supposed to say 325
Old 01-22-2010, 09:30 AM
GwarForAll1021
Know any buddies who work tire shop? Maybe have a 275/65-18 to try on that front end?
my truck is factory with 275/65.
Old 01-22-2010, 07:13 PM
tbear853's Avatar
tbear853
tbear853 is offline
Question
Yeah, I know.... 275/65-18. ..... oh damn, I see my mistake .... I'll go fix it now.
Old 01-22-2010, 07:25 PM
bigyeller's Avatar
bigyeller
They don't bulge bad. At least mine don't. There is enough clearance as well. I got no wheel rub unless i have the wheels turned as far as they will go in either direction. Thats only because of the large tires and a leveling kit. When i had the 305/65's on they wouldn't rub at all. I just didn't like so much wheel well showing so i decided to go bigger the second time around.
Old 01-23-2010, 07:01 PM
silver05fx4's Avatar
silver05fx4
silver05fx4 is offline
i had 305 70 18 and had no tire issue at all
most tire shop won't install anything but oem size just because they don't want to deal with it
Old 01-24-2010, 12:59 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
thought I had posted this up for you...but I guess not???
a 12.5" width is cool, but the rubbing would get annoying at times. you thought about a 11" or 11.5" width?
I personaly would order up a set of tires from Tirerack.com and avoid the local guys. The more I deal with local shops, the less I can stand them. I just paid $60 yesterday to get 2 tires mounted on my Mustang...They even charged me $20 to handle my "wide/low profile" 18 rims.
Tirerack has the sizes above in the Goodyear Silent Armor and the Duratrac...both are awesome tires
Old 01-25-2010, 01:33 AM
catskinner789's Avatar
catskinner789
catskinner789 is offline
I have 35x12.5 on the stock 18 inch rim and i have had zero problems with them and they have only about 20% tread left on the tires.
Quick Reply: to those with 12.5 wide tires on factory rims
