1977 F100, Stock Restoration & 4x4 Conversion Help !
Guest
Posts: n/a
I have a 1977 F100 Custom Pickup Truck that I want to do a full Stock restoration & Stock 4x4 conversion on. I have had the truck since 1984(2nd owner) & it is still in super condition. Does anyone know of any reputable Resteration & 4x4 Conversion shops in the VA & NC area ?
THANKS, Dan
THANKS, Dan
Dan most of the guys here do their own work. You may post on the hod rod and custom discussion for better help, on restoration companys. I think they get around 10 to 20 thousand dollars for restore work, and that elemanites most of us here. As for 2wd to 4wd conversion, you need to find a late 70s 4X4 truck with the same engine family and swap your body and engine onto. Trying to change the chassis - drivetrain to yours, is cost prohibitive. The drive line is different and the chassis is narrower, but your sheetmetal will bolt on it.
John
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
John
66 F100s
