1966 F-100, 460, C6, Power Steering, Power Brakes more
Year: 1966
Make: Ford
Model: F-100
Price: $2750
Mileage: 10000
Color: Yellow
Private or Dealer Listing: Private Listing
Location (State): SC
Transmission: Automatic
Drivetrain: Rear Wheel Drive
Color: Yellow
Engine: 460
This truck needs someone to do the body work and paint job to make her beautiful again. I cannot do that, and do not have a place to do it. I have kept a camper top on her since I bought her so there is no rot in the tailgate or bed.
She comes with nearly $2,000 worth of spare and replacement parts; see the list below. I also have contacts that can easily get you more parts, a complete replacement cab for example, in the Atlanta area.
Here is the bad: The cab has a dent in it from when someone bent the door back while I was deployed. This allowed water to seep in and rust the floorboards. They are still solid enough to sit on, but there are holes developing.
The core support has a large rot area - I have a replacement core support ready to be installed, though.
There are miscellaneous dents all over, but the sheet metal is solid and rot free, except as already noted.
Please contact me by e-mail, by responding to this ad, or by phone at 443-617-6143.
Truck Description
‘86 460 bored 60 over with stock '86 heads - no porting
'77 F-250 460 engine perches and mounts
'69 straight up cam gears, Cloyes 3-position gear, double roller with RV type cam
Edelbrock Performer intake and 1470 750 CFM carb on a 1" phenolic spacer
'76 Duraspark II ignition
Stock aftermarket manifolds with a 2 1/2 inch dual crossover exhaust, Flowmasters, copper gaskets
'93 serpentine belt brackets and pulleys
'78 power steering pump, hoses with ’93 PS pulley
'76 power steering box
’76 power steering pitman arm
’92 power steering cooler, mounted inside the frame
'70 rebuilt steering column
'66 radiator (re-cored)
'66 alternator with '93 serpentine pulley and fan
'86 water pump
'86 fan clutch with '77 7-blade fan
'83 rebuilt C-6 from an '83 F-350 fifth wheeler, with '77 C-6 linkage (internal shift rod and kickdown)
2.75 rear end
'83 stock rear sump oil pan, with stock oil pump, pickup tube and dipstick (includes main bearing bolt with stud to hold pickup in place)
Includes '93 A/C compressor, but A/C is not installed. (Needed for the serpentine belts.)
’76 F-150 3-inch rear brakes (with ’72 axle shafts)
’76 F-150 front disk brakes with power brake booster and dual chamber master cylinder. Re-plumbed brake lines
Front end rebuilt
Rear end rebuilt
Major Spare Parts List
Rust-free hood
New radiator/core support
Interior trim set
Exterior trim set
Automatic steering column with steering wheel
Second set of original hubcaps
Rear end third members, 3.50 and 3.25 ratios
Spare set of '72 rear axle shafts
Spare gas tank with sending unit (very hard to find clean!)
Complete spare wiring harnesses
Original radio
Many electrical parts
Door and hood hinges
Set of 4 wheels and tires
Much more in other parts
