Throttle Body Cleaning
Old 01-01-2010, 12:51 PM
pb34's Avatar
pb34
pb34 is offline
I tried searching for a thread with specifics on cleaning the throttle body but I couldn't find one. I know it is a good idea to clean the throttle body every once and a while and I have around 40k miles and figured it would be a good idea to do it now.
Is there anything that I should be careful of while doing this? Is there any specific way to clean it or any cleaners to use? I just don't want to mess anything up while doing this. Any help is appreciated! Thanks!
Old 01-01-2010, 01:21 PM
60DRB's Avatar
60DRB
60DRB is offline
make sure the cleaner says it is for throttle bodies
put rags or towels under/around the open end to keep from over spraying or dripping onto other parts etc ...NOT good for rubber/plastic/paint
use an unpainted wooden dowel (not plastic and DEFINATELY not metal) to hold the throttle body plate open (at the bottom side)
expect the truck to be rough and make you think you ruined it when you restart...sputtering, check-engine light, etc
after about 30-60 secs, shut off the engine then restart and all will be fine.
Old 01-01-2010, 08:59 PM
pb34's Avatar
pb34
pb34 is offline
Alright so it's that simple? Any good cleaners that people like?
Old 01-01-2010, 09:10 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
truck shouldn't react at all...if anything, it should run smoother.
I used rubbing alcohol (no no...but all I had at the time) to clean it. used a clean lint free shop rag
basically soak the rag with your cleaner of choice...to be honest, I think anything would be fine as long as you keep it only on the metal.
also make sure to clean the upper/lower sides of the TB plate.
when I did mine, it was absolutely filthy. @ 23,000 miles. There was crap caked on the edges of the butterflys, and a decent layer on the whole thing.
Old 01-01-2010, 09:27 PM
60DRB's Avatar
60DRB
60DRB is offline
I'd bet they all use the same chemicals. I shot about half a spray can through mine while the engine was off. That may be why it was so unhappy on the first start-up. I didn't have anybody around to mash the gas while the engine was running...
Old 07-11-2010, 06:37 PM
geogman2's Avatar
geogman2
geogman2 is offline
I took the throttle body off and cleaned it. It was real easy to do, only took 1/2 hours or so. I did it while changing my plugs.
Old 07-11-2010, 07:12 PM
tolliewolly's Avatar
tolliewolly
tolliewolly is offline
Where is it? I would like to clean the one on my 4.6 ford. Any instructions on how to do it?
Budman1962
2009 - 2014 F150
06-20-2016 09:23 AM
GadgetGuy22
1997 - 2003 F150
05-26-2016 12:03 PM
tankeryanker73
1999 to 2016 Super Duty
07-01-2010 02:43 PM
SJHanlo
16
02-20-2005 08:57 PM
JTD1972
1978 - 1996 Big Bronco
06-18-2003 07:16 PM
Quick Reply: Throttle Body Cleaning
