Coolant and Test Strips
I am in Mexico and I just had some radiator work done. I bought 2 gallons of Fleetguard concentrated coolant, pre-charged with 5 units of DCA and had the mechanic put it in. 2 weeks later I got some test strips and the following readings; Nitrate 4000 flush, freeze point -10, PH 8.
Do I have to flush the radiator or just dilute the antifreeze down?
I hear you there. diluting your coolant may just work. I had my international in the shop once for a heating problem I couldn't figgure out that turned out to be the new batteries I had installed. Any way when I went to get the truck he said he had to dilute the antifreeze back to -34 to get it right. I was a little peod because I had to run -60 and that was more important than the ph or nitrate count.
I never saw the numbers so I'm not sure what he was getting right but he did dilute so if I was you I would dilute it and check it again seems like you should be able to go to -34 though maybe you just have too much additive. I always fill with coolant then test and add accordingly.
Living in the tropics, I don't need to worry about freezing. I am more concerned about proper protection from cavitation.
What problems could I encounter from running a higher concentration of coolant or additive? BTW, there is no expiration date on the container of test strips.
I will dilute it down this weekend and re-test.
Thanks for the advice and have a happy new years
I am just going to flush the radiator and start fresh. I have a pint of Motorcraft diesel cooling system additive. Do you guys recommend using the pre-charged Fleetguard antifreeze or just getting regular antifreeze and using the additive? What kind of % mixture with water should I use?
BTW the truck ran cooler with the coolant diluted, normally I run about 190 but on the last drive it stayed about 180 even with the A/C running. Strange?
Allstar recovory
6.4L Power Stroke Diesel
12-24-2013 01:31 AM
whiteboyslo
03-11-2012 07:04 PM
cornking
25
05-06-2010 02:45 PM
