What are the differences in the 4R100~ 4R70W~ E4OD
Hi
I was wondering if anyone knew what specifically are the differences in the three transmissions?****** http-equiv="Content-Type" content="text/html; charset=utf-8">****** name="ProgId" content="Word.Document">****** name="Generator" content="Microsoft Word 10">****** name="Originator" content="Microsoft Word 10"><link rel="File-List" href="file:///C:%5CDOCUME%7E1%5CKelly%5CLOCALS%7E1%5CTemp%5Cmsoh tml1%5C01%5Cclip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} </style> <![endif]--> 4R100
4R70W
E4OD
I have the E4OD in my 2000 EB Expy. I do haul a 16' car hauler with a five thousand pound Genie scissor lift with it.
I am curious to know if one transmission is better than the other for future reference when this E4OD tranny goes.
Merry Christmas and Happy New Year!
Kelly
4R70W
E4OD
Kelly
4r100 & the e4od are basically the same trany. the 4r100 is an updated e4od and made to bolt up to the modular motors. the 4r70w/4r75w are smaller tranys and are an updated aod/aode and made to bolt up to the modular engine family. the 4r100 is the same trans put behind a diesel and very relible when taken care of.
Your 2000 Expy already has the 4R100 if it is a 5.4L. They stopped making the the E4OD after 1998.
I wouldn't expect the trans to give for a long time unless you are not caring for it. I got a solid 200k out of a 4R100 behind a 7.3 deisel in a '99 F350. That truck was either pulling 15k lbs or plowing a 10 acre yard in northern Minnesota all its life. It hadn't even failed at 200k but was rebuilt as preventative maintenance. It did get 30k trans fluid flushes and filters though.
Luch
18
04-15-2013 09:42 PM
porthole
6.7L Power Stroke Diesel
12-25-2010 09:25 PM
JPs2003
10-28-2010 08:50 AM
00, 2002, 4r100, 4r70w, compare, difference, differences, e40d, e4od, eo4d, expedition, f250, ford, upgrade, vin
