Pulling the 350, putting in a 351
The "Ford in a Ford" finally got to me; decided to deep six the GM350 in favor of a 351M in my '54. Found a freshly pulled (rebuilt) engine from an '82 F-250 with 35,000 for $250. Be interested in hearing from anyone who's done this: what's worked for you, what NOT to do, what engine mods were done, that sort of thing. Could use some advice on which automatic (C4 or C6?) best fits. As always, thanks for taking the time to respond.
My honest opinion? Well, I've had a 55 F-100 with a Ford 289/3sdpOD; a 56 F-100 with a 351C and a C-4; and a 51 F-1 with a 390PI and a C6.
The 289 was a great power train - great mileage, fair power, easy to work on and lots of available parts. The 390 has been a little tough to find parts for, has required special exhaust, negated use of an IFS, the C6 required quite a bit of frame mod, and it gets lousy mileage (up to 14 -15 now) - but it is powerful and a fantastic drive train from a performance standpoint.
The 351C - which is the early variant of the 351M was a complete dog. It didn't pull the 56 any better than the 289, took up a lot of space, was heavy, and just an all around nothing. I had a Camaro with a 350 in it. My honest opinion is if you want to take th e350 out and put in a Ford motor you should invest in a 351 Windsor. It's a small block, lighter, (so your exhaust etc will fit better) parts are plentiful, and the performance is BETTER than the 351M. For transmissions I would install an AOD.
If it were me I would NEVER replace a working Chevy 350 motor for a 351 Cleveland or Michigan Motor--- Sorry, but YUCK!
on
1 Post
I am pulling a buick 3.8 out of my 51 and replacing it with a 5.0 EFI setup by FAST along with a c4 transmission. I would prefer a 351w over a 351M just because of the performance value and the ease of getting parts. I keep thinking 351w but the 5.0 is going to serve me better for a driver.....
on
1 Post
For me, I always wanted to go to a Camaro Nationals with a 69 Pace car, equipped with a 352 under the hood, just to spite 'em.
If you can get the trans from the same truck, (assuming it's an automatic, and not a 4x4) that would save a lot of work. I've never seen a C4 with the big block-style bellhousing, so your choices of transmission may be limited. The E4OD automatic overdrive trans may be a good option for you. Fortunately, there's a lot of room in a '54, so you shouldn't have too much trouble making your drivetrain combo, whatever you choose, fit just fine.
Congrats on your decision to go 'All Ford!' ;-)
But truth of the matter is it doesn't stand for anything. Ford assigned the "M" designation simply to distinguish the engine from the 351 W (Windsor).
