CHECK FOR A VACCUME LEAK AT THE PCV ELBOW FOR THE LEAN BOTH BANKS.AND SUB A NEW COIL IN THE NUMBER 3 HOLE.CHECK THE # 3 PLUG FOR A LINE OF BLACK DOWN THE SIDE CALLED A CARBON TRAIL.
ya i will check the vacume leak at the PCV elbo, im pretty sure there is one somewhere already as the truck will switch to defrost from vent from time to time.
