1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
05 sd front sway bar problems
Old 12-06-2009, 01:29 AM
superduty steve's Avatar
superduty steve
superduty steve is offline
I am having a problem with the driver side front sway bar bushing on my 05 SD F350 4x4. I put on a front leveling kit about a year ago and the sway bar bushing has worked its way out of the frame bracket. This is the second time in about 5 months that it has done this. The truck only has 51k on it. I have worked on alot of Fords 4x4s and classic fords and I have never seen this happen before. Has this happened to anyone else out there who has put on a front leveling kit mine is from rough country. I had to buy new longer front shocks too they are rancho rsx9000 series. My thought is that maybe the end links are to short with that kit in there but then wouldn't both bushings squeeze out of the brackets? Any help would be appreciated! Thanks.
Superduty Steve
05 SD CC lngbd
dark stone metallic
k&n cold air kit
64 falcon sprint hipo
64 falcon sprint conv.
65 falcon ranchero deluxe (the patch adams movie truck)
rough country leveling kit
Old 12-06-2009, 11:09 AM
motown's Avatar
motown
motown is offline
I would say once it has been pulled out the bushing is pobably going to keep coming out. You may want to chnge to a polyurathane sway bar kit. It would be prettty tought to pull one of these bushings out. But it sounds like some undo stress is causeing the sway bar to slide cross car. You may want to contact Rough country and ask them if you should be using a longer link.
Old 12-06-2009, 02:35 PM
superduty steve
re front sway bar problem
Thanks for the reply Motown. I would really like to upgrade to poly bushings on that truck I have checked energy & pst web sites but there is no part# for the 05 on up. Has anybody out there done this to an 05? I did look at that bushing & you are right it probably would pull out again. I did email both company's so now I will await their replys
thanks again
Superduty Steve
RUNVS
Ford Truck Parts for Sale
06-30-2014 05:54 PM
snowmobile mike
13
05-20-2011 09:22 AM
itsaford
06-09-2010 09:36 PM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
12-16-2006 01:21 PM
gocars
02-08-2005 12:21 PM
Quick Reply: 05 sd front sway bar problems
