84 F150 Frame Question
*facepalm*
DO NOT try to fix rust with bondo. That is the most half-assed way to go about it. It isn't durable, will probably just fall off eventually, plus bondo isn't for filling holes in the first place. And it doesn't address the issue at hand, which is that your body is rotted. You need to replace the metal with patch panels (please don't just rivet them, do it right and weld them in).
Alright, I requested one and Ill check it out when it gets here, but on the webpage It showed that they sold an inner fender for the left side but not the right. And the thing that confuses me is they show a support for the inner fender for the right side but it says nothing about having an inner fender for the right side. Maybe Im just missing something or im stupid (which is very likely).
No, he's right I don't see it on the list... hmm that's weird. I would call them and ask if there is some kind of error in their listings. Also check out Bronco Graveyard's website, I have bought a ton of stuff from those guys. Their service is great, prices and part selection is pretty good too.
Rich, you should get under that truck and start writing down everything you see that you'll have to fix. Go over the inside(under the carpet,mats ,firewall and the bed,doors fenders etc-wheel wells also) then take that list and pick it apart. Find out what it'll cost you 4 the stuff you will need 2 fix everything. Remember 2 try to be thorough and ask questions if you don't know like you're doing now. There's plenty of people here more than willing to pass on their know how and good advice is a boon. Any rust will have to be cut out and another piece welded in it's place. Bondo should never be more than 1/16th of an inch thick. Yeah some use it as a filler to cover up major damage but that's only gonna create another problem down the road and there's no sense fixing anything twice(WASTE OF YOUR MONEY AND TIME). I'm not a pro myself but I ran a body shop for awhile and like the rest of the people on here have tinkered on my rides for many years so feel free to hit me up and hopefully I can help you along. By the way the frames on these trucks can usually be fixed with some cleaning and paint.
#28
#29
#30
Rich, I know what you mean about this being a good forum. I get help each time i've asked and it helps. There seems to be an abundance of knowledgeable and good people here. As far as fix'n w/cleaning and paint I'd say it's very possible but I'm not familiar with how bad the cancer can get to the frame back there. Being out here in so.cal. I've rarely run across significant rust in anything other than 40 year old or older vehicles and that rust is usually all in the lower fender area's,also part of a floor pan at times. Lower doors,1/4's and at the bottom of the rear windows---especially on vinyl top stuff---. But hold out and wait to see the thing and then see if you can scrape away what you do see with a wire brush or wheel and see how bad the metal is fatigued(ate up). I hope you get lucky .
