1966 Brake Upgrade Question
Old 11-29-2009, 12:38 PM
santi2322's Avatar
santi2322
santi2322 is offline
I know a lot of you recommend gettting 73-79 brakes to upgrade a 66 but what about using an 84 or 85 F150 Brake parts. My uncle has one just sitting there and wondering if the parts would work on my 66. Thanks.
Old 11-29-2009, 01:47 PM
banjopicker66's Avatar
banjopicker66
banjopicker66 is offline
No, unfortunately. Not even a close fit - although close only counts in hand grenades and nukes anyway!
Now the power booster and master cylinder MIGHT work. I know the rear brakes from an '80s Ford 9" can be swapped, if you use '72 axle shafts on the '66.
Check with AutoZone, Advnace or similar to see if the rotors and calipers are the same. If so, that might save some money. The bell crank for the booster might work too, but you will have to trial fit it to see if it can be made to fit. Seems as I recall when I checked this out, that it was a no-go also.
But the spindles, no, will not work.
Old 11-29-2009, 06:28 PM
peganit2's Avatar
peganit2
peganit2 is offline
Sorry for the double inquisition! I didn't think that it would be the same question!
Old 11-29-2009, 06:29 PM
peganit2's Avatar
peganit2
peganit2 is offline
What about the whole I-beam set-up?
Old 11-29-2009, 06:51 PM
peganit2's Avatar
peganit2
peganit2 is offline
IIRC the 80-96 booster is direct acting and the 73-79 booster has that funky rocker in it. They won't bolt on, but may be close enough make work. The master cylinders themselves WON'T interchange.
Looks like we''l be looking for the 73-79 parts.
66nut
25
02-19-2021 05:49 PM
smkf100
07-03-2010 11:58 AM
66F100Again
03-09-2007 03:36 AM
pockets
15
02-19-2005 07:43 PM
proud66owner
01-28-2001 05:36 PM
Quick Reply: 1966 Brake Upgrade Question
