Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 11-24-2009, 04:15 PM
fordfinatic fordfinatic is offline
Garage is empty, add now
fordfinatic is starting off with a positive reputation.
1995 ford f350 7.3 SHIFTING PROBLEMS
I got a 95 ford f350 with a 7.3 and its automatic. About 2 weeks ago it started shifting wierd with the speedometer acting wierd. I did a code scan and it came up with PO500 a vehicle speed sensor malfunction. So i replaced it and cleared the code and it ran fine for two weeks then last night i took the truck out and the speedometer wasnt working and it started shifting crazily and hard. so i did another code scan and it came up the PO500 again. So i replaced it again and its still acting wierd.
Any thoughts on what keeps causing the problem guys?
THANKS
  #2 (permalink)
Old 11-24-2009, 09:54 PM
DAVID'S97F250HD's Avatar
DAVID'S97F250HD DAVID'S97F250HD is offline
1997 Ford F-250
DAVID'S97F250HD is starting off with a positive reputation.
THANKS
Check your wiring, start from the sensor, thats all I can say.
__________________
1997 F250HD, 4x4, extended cab, e4od, 3.55 gears.
ENGINE:3 inch DP, kittiless with no muff, 10k mod, hpx line, 6637 filter, SD 120 IDM.
TRANS:trans cooler, temp gauge, tugger shift kit.
SUSPENSION:BDS front leveling springs, urathane spring bushings.
DIFF:Yukon power lock front diff, OEM LSD rear diff.
  #3 (permalink)
Old 11-25-2009, 09:21 AM
rideracelivemx7's Avatar
rideracelivemx7 rideracelivemx7 is offline
1995 Ford F-250
rideracelivemx7 is starting off with a positive reputation.
its a 25$ part from ford, its on the very top of your rear axel housing, you cant miss it, your speedo will be off and your tranny cant tell how fast its going so it was shift way to early or way late. replace it and forget about it. its 1 8mm bolt and it pops out.
__________________
Steve
1995 f250 ECLB,silver/purple 160k rosewood 250/100 hybrids, zf5, Gearhead Tuned, glowshift EGT,Boost,fuel pressure, 6" chrome aussie stacks. 265s,6637, 6.oh IC, dual sd reg return, cooling mist stg1, 490/809tq ? s471 from irate,t500, ARPS, comp 910s, BTS
Plans: s485 twin, t1000
  #4 (permalink)
Old 11-25-2009, 03:00 PM
i checked and it looks good and thats what i already replaced twice
  #5 (permalink)
Old 11-26-2009, 12:25 AM
don77's Avatar
don77 don77 is offline
don77 is starting off with a positive reputation.
did you get the sensor from ford or auto parts the other brands dont work good for some resine
__________________
im Don
no truck for now
  #6 (permalink)
Old 11-26-2009, 02:12 PM
i bought it from an auto parts place but its a motorcraft sensor
  #7 (permalink)
Old 02-20-2011, 08:19 PM
burnz406's Avatar
burnz406 burnz406 is offline
burnz406 is starting off with a positive reputation.
fordfinatic, i know this is kinda old, but did you fix your problem? my 95 has the same problems and besides checking wires and changing the speed sensor(along with other waste of times...) i am now bout to change the speedo cluster out. mine comes and goes, but i think ive narrowed it down to the speedo. just thought i would look for some more thoughts on it.
  #8 (permalink)
Old 02-20-2011, 08:44 PM
jiveturkey692000's Avatar
jiveturkey692000 jiveturkey692000 is offline
jiveturkey692000 is starting off with a positive reputation.
Quote:
Well its not a diesel but a friend of mine has a 95 F150 with a gas engine and it would shut off at stop signs and randomly idle weird. After changing a bunch of sensors and stuff it turned out to be the speedometer guage. Changed the guage and it was fine. So I guess it could be tied in on a diesel to?
__________________
Dan
05 F250 4X4 CC 8ft bed. 6.0 auto
82 Dodge W350, 360, 4spd, 4X4, Extended Cab.
95 Jeep Grand Cherokee 318, AT, 4X4, 2" lift, 30" tires
96 Fleetwood Mallard TT, 30ft/ 79 Trans Am 400, 4spd.
  #9 (permalink)
Old 02-20-2011, 09:10 PM
MADVAN's Avatar
MADVAN MADVAN is offline
MADVAN has a very good reputation on FTE.MADVAN has a very good reputation on FTE.MADVAN has a very good reputation on FTE.
I wiring tests fine from the pcm to the sensor
And nothing is bad on the tone ring move to the PSOM.
You cannot repair the PSOM
Bill
__________________
97 4X4 PSD Quigley
  #10 (permalink)
Old 02-20-2011, 09:39 PM
burnz406's Avatar
yah, alot of brake cleaner, some time with a trouble light and and a compressor, my wiring looks and checks good, pulled the cover on the rearend, ring looks good, replaced sensor and plug(Ford parts), even changed the shift sensor on trannie, it was cracked and broke anyways...
I am pretty sure its the PSOM cause after i pulled it out blowed it out, put it all back together, the shift probs never came back for quite a while. also the last time it happened, after ever so tapping, uhh err, hammering on the face of the speedo, it came out of it. ive found a couple used clusters online and figuring on going that route next. then its onto the exhaust heat prob, but thats another thread....
  #11 (permalink)
Old 02-21-2011, 02:36 AM
BuckHammer's Avatar
BuckHammer BuckHammer is offline
1996 Ford F-250
BuckHammer has a good reputation on FTE.BuckHammer has a good reputation on FTE.
Pilgrim812
I had a similar thing happen to me. I went through 4 or 5 Borg Warner speed sensors, and eventually went with a Motorcraft from RockAuto, and the Motorcraft has yet to fail me. However, I changed the fluid in the axle at the same time I put the Motorcraft in, so it could have been the new fluid that helped, too. If I had to guess, though, I'd say it was the crappy Borg Warner sensors.
Use only Motorcraft and good luck.
Edit: I actually read the entire thread and see that you've already got a Motorcraft in it. From here, I would go ahead and change the gear oil in your rear axle. While you have the differential cover off, go ahead and inspect everything in there and make sure it's in working order, especially the tone ring.
__________________
Joseph
1996 F-250 XLT 4x4, "Heavy Metal", 7.3L Powerstroke, ZF S5-42 transmission with Valair clutch and flywheel, Supercab, 8' bed, Riffraff 6637, HPX, Dieselsite 203 degree thermostat, 3" Downpipe to 4" straight pipe exhaust.
"you are not a troll. a pain in the --- sometimes, but not a troll." - tjc transport
  #12 (permalink)
Old 02-21-2011, 02:30 PM
kupiec20's Avatar
kupiec20 kupiec20 is offline
kupiec20 is starting off with a positive reputation.
i had the same problem. once i changed the pigtail to the VSS it was alset! good luck
  #13 (permalink)
Old 04-25-2012, 08:17 AM
BEAST428 BEAST428 is offline
2003 Ford Excursion
My Garage
BEAST428 is gaining momentum as a positive member of FTE.
I recently had my E4OD rebuilt and the first time I took it out the trans shifted hard and erratic. Then I noticed the speedometer and odometer weren't working. I also saw the interior lights weren't on either. Tracked it down to #8 15 fuse. Works now!! Who would have thunk it?
Tags
1995, 1997, 73, codes, diesel, f350, ford, gauge, location, sensor, speed, spring, temperature, truck, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
