Texas Chapter Join Chapter, Leader: LibTimothy
Truck update
Old 10-01-2002, 02:35 PM
Rosati's Avatar
Rosati
Rosati is offline
Truck update
Finally finished all of the chassis work. Brakes, lines, paint are all done now still have to locate a tank and weld in engine mounts.
I have moved to the cab and already replaced both floor pans. This weekend I will be doing a cab corner and trying to fab some curved metal top repair both lower cowls. Whn I finish that, I have to deal with some rust over both drip rails/rain gutters.
I am open to suggestions on the last one (except for covering with bondo)
Old 10-04-2002, 07:12 AM
bandit99's Avatar
bandit99
bandit99 is offline
Truck update
The roof is probably one of the worst areas to have to deal with. I filled the majority of mine with lead, then used a fiberglass filler over that. The problem I had is that my rust didn't show till i started working on it. The paint was just about all that was left. Good luck~
Old 10-04-2002, 09:19 PM
66 Ranger's Avatar
66 Ranger
66 Ranger is offline
Truck update
Why don't you get a good cab and cut the roof off it and install it on yours. Sounds like you have already spent a lot of time on the rest of it.
Old 10-09-2002, 07:11 PM
GolferSA's Avatar
GolferSA
GolferSA is offline
Truck update
