87 TAD/TAB vacuum lines
i have a 1987 f-150 4x4 with a 4.9.i want to make sure i'm putting the right vac line on the right solenoid.from front to back,EGR has green vac hose on top connector,green and red wires. middle one has red vac line on top connector,red and white w/black stripe wires. back one has black vac hose on top connector,white w/black stripe and red wires.the two solenoids i got from the junk yard are; red and white w/ red dashes wires on one,the other has red and white w/black line wires.what vac line goes with what solenoid?i have a red vac line and a black vac line.i just want to be sure,any and all info would be great. thanks
got the TAD/TAB solenoids in and they fit with a little mod.hooked up my code reader and the codes for that were gone.the only code left i code 67.book saysimproper signals are being recieved from either neutral drive switch,neutral gear switch, neutral pressure switch,manual lever position,or A.C.clutch.
79Supercab
02-22-2015 10:16 PM
joegeds
11-27-2013 05:39 AM
Murf77
09-12-2011 09:34 AM
BRay09
08-03-2010 03:22 PM
sg1099
11-06-2009 11:31 AM
