Coolant Leak 4.9
Coolant Leak 4.9
So last night I noticed that some coolant was leaking towards the front of my engine (4.9L) in my 1990 F250.
I looked all over the place trying to find the name of the part circled in red (I'm a n00b DIYer). Its not actually pictured in any of the tear down instructions in my handy-dandy Haynes manual. Can someone please tell me the name of it? And does it look like it might just need a new gasket? It looks like there's a metal gasket between it and the head...
Thanks Guys!
Thanks Guys!
What is the correct position of the thermostat btw? I replaced mine the other night with a 195F and put the new one in just like how the old one went and never gave it any thought....until now.
The reason I changed it in the first place was because it never seemed to come up to temperature (straight up and down) in 'normal' by dash gauge anyways. It stays constantly just before the 'N' in 'Normal', even after a long drive. clutch fan turns without too much resistance(seems normal) and coolant doesn't seem to be low/too high and tested to -30(fine). After replacing t-stat, cleaning t-stat housing temp sensor, problem still persists.
Yes, gauge reads stone cold when cold and slowly climbs to almost just touching the left of 'N' after alot of driving. Pointy end towards rad eh? Then mine was previously installed incorrectly then. I took it out with the pointy end in the head.
I've only had the truck a couple months and it's usually always short around town trips. So it always ran cold since I got it. Perhaps this is the reason?
So you are 100% certain the correct direction of the t-stat on a 4.9L six is pointy end faces the rad? I just don't want to do the job of flipping it around on a hunch. Thanks.
Heh fine with me, its stuff I need to know
Yessir! Didn't want too much power, I'd be getting into trouble...
Originally Posted by brett12396f150
@ mrbubble: does an f250 really come with a 4.9 six? O.o never seen that.
300s came in large dump trucks too...every ford truck produced during the 300s reign of terror offered the 300...for good reason
if i remember correctly the spring of the Tstat goes towards the block? thats how the 302 was anyway...so if thats wrong i guess it doesnt matter cause it works
also when you throw the Tstat back in give them bolts a bit of the silver anti-seize stuff about half way up the threads...make it nice an easy for next time...i do that with anything i can and trust me, you will thank yourself
when you did that housing and gasket did you put a new T-stat in? should have...its like $7, cheap insurance
